-   -   Tuning a modded engine to pass CA smog? (http://forums.pelicanparts.com/porsche-911-technical-forum/361983-tuning-modded-engine-pass-ca-smog.html)
umfan866 08-14-2007 03:23 PM
I'm looking at a 1987 911 3.2 /G50 with recent top-end rebuild and these mods:
Upgrades
964 cam upgrade
SSI headers
Dansk Sport Exhaust
Downgrades
Catalytic converter has been removed
Could this 911 be tuned to pass CA smog? I know that it may fail visual inspection, due to the SSI's but apparently some people can tell the smog person that it is a "dual cat" system when he/she questions it.
However, could one adjust the mixture to actually pass the pipe test, including the more recent one on the dyno?
JP911 08-14-2007 03:29 PM
Give S-Car-Go and/or Porboys a call. Keep in mind that the mixture cannot be adjusted on a Carrera without changing the DME software.
ischmitz 08-14-2007 03:37 PM
I have heard that it helps if one injector plug isn't properly seated.... ;)
Joe Bob 08-14-2007 05:50 PM
You need a cat to pass the visual inspection. Best to see how it does on the pipe test PRIOR to going to the smog test. Getting tagged as a gross polluter sends you to the BAR and THEY run engine numbers.
Test it, HOT and if it passes..... then take it to a "Billy Bob" tester that does Chevies....they will probably miss the lack of cat.
ianc 08-14-2007 10:13 PM
Idle mixture can be adjusted via a 3 mm allen screw in the AFM. Off-idle mixture can be adjusted via some finagling with the flapper spring tension once the AFM's cover has been removed. A properly functioning O2 sensor should be able to correct unless the engine's at WOT however,
ianc
umfan866 08-14-2007 10:29 PM
Thanks guys!!
Hey Ian - hows it going?
I talked to the seller today, and he said that after all these mods, it still passed the Washington state smog test without the cat at all!!!
The bad news is that at this point another buyer has gotten to it first, and is having the PPI done, he's also from the Bay Area. So we'll see I'm not as worried about smog now.
