Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
dweymer's Avatar
DIY tach repair
I have searched, and found various threads on tach dampening, but none on how to actually repair the dampening. Can anyone post a detailed description on how to do it.
Donnie
Currently Porsche-less.....
Old 08-15-2007, 05:10 AM
did you search
tach Early_S_Man
he's the best
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-15-2007, 06:14 AM
dweymer's Avatar
yes, Warren is the man; but most responses deal with voltage issues or points. My tach does not jump around, it just overshoots then stabilizes, thus dampening.
Donnie
Old 08-15-2007, 06:52 AM
ok..
all i know is that there is a spring in there somewhere that weakens with age. My tach stabilizes at 100rpm less. I imagine it could cause other problems?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-15-2007, 09:17 PM
304065's Avatar
Donnie,
Buy a NEW VDO tach, they are about $80. You will find the movement nearly identical and the electronics an updated version of the old one-shot. Swap the insides and you're off.
There is a great deal of inertia in the old VDO movement, mostly because it's all metal. Ron's right, there's a hairspring that causes the needle to return to zero, and like all springs, it fatigues with age.
'66 911 #304065 Irischgruen
Ex-'88 Carrera (Sold 3/29/02)
Old 08-16-2007, 05:53 AM
dweymer's Avatar
I am on my second used tach, so that is getting to be a possibility. Palo Alto quoted $115 to rebuild mine so I may do that too. Just wanted to know what exactly they were doing, 'cause the insides are all magic smoke to me
Donnie
Old 08-16-2007, 06:37 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
