-   -   3.6 conversion question (http://forums.pelicanparts.com/porsche-911-technical-forum/362161-3-6-conversion-question.html)
beamonk 08-15-2007 03:04 PM
Guys, I am running the DME harness in the car. Do I nees to route the harness over the heater duct like next to the fuel lines or below the duct along the body seam?
DW SD 08-15-2007 03:19 PM
I ran mine over the top of the rear shock cross member and around the shock towards the rear. The bundle was between the body and the rear shock mount cross member. I had to use a prybar to create enough space between the crossmember and the rear seat firewall sheet metal.
Doug
Bill Verburg 08-15-2007 03:31 PM
Here's a pic of mine
http://forums.pelicanparts.com/uploa...1187217069.jpg
DW SD 08-15-2007 03:39 PM
Bill fashion of doing it is nice. I already had a hole closer to the trans tunnel, so I routed mine to take advantage of the hole.
As always, a picture is worth 1k words.
Doug
beamonk 08-15-2007 06:59 PM
I like bill's idea, but I have routed the wires through the shock tower area and drilled the hole below the torsion bar as per Timmons instructions. Should I run the harness like an A/C line along the seam or over the heater duct?
