touch up paint
I recently had some body work done on my targa and the body shop gave me half a quart of the paint that was color matched, so i went a long and started touching up all the chips on the front of the car....
here is the question....
the touch up paint is duller, is there a way to polish the spots I've touched up?
Old 08-17-2007, 10:03 AM
scottb's Avatar
Do a search here on the board. There are lots of threads about touch-up. Likely what you'll end up doing is a careful wet-sand with 2000 grit paper, and then polishing with varying degrees of aggressive polish, followed by a good wax.
1984 Targa
Old 08-17-2007, 11:50 AM
onboost's Avatar
The "touch-up" may be duller because it is probably just base coat.. no clear. You need a cler on top for the shine.
RGruppe #180
Old 08-17-2007, 11:55 AM
scottb's Avatar
Good point! He'll still likely need to do some wet sanding and polishing after the clear coat has dried to get it to blend properly.
1984 Targa
Old 08-17-2007, 12:01 PM
thanks for the advise, I'll try the sanding, some rubbing compound, then some polish and wax (under the bumper would be a good inconspicuous spot to test)
Old 08-17-2007, 04:14 PM
