-   -   front glass trim delete ??? (http://forums.pelicanparts.com/porsche-911-technical-forum/362476-front-glass-trim-delete.html)
Karb 08-17-2007 01:52 PM
I see the host sells the rear windscreen rubber without the
trim groove, but is there a gasket like this for the front glass.
Karb
TRE Cup 08-17-2007 04:08 PM
964 front windshield seal BUT you may have to shim the edge of the w/s to push the rubber out far enough to seal properly
dweymer 08-17-2007 04:37 PM
I used the regular gasket, but molded and put 1/8 welding rod into the grove instead of the trim.
70SWT 08-17-2007 05:38 PM
Need pics here...
What appearance does this create? Any leakage problems?
Formerly Steve Wilkinson 08-17-2007 07:09 PM
I spent all last winter in the barn trying to fit a Lexan windshield into a 964 seal on an '83 SC and I haven't got it done yet. Figgered I'd rty again next winter, but believe me, it ain't easy...grind some, fit some, grind some, fit some...
Karb 08-18-2007 04:22 AM
Interesting thoughts here. I was hoping a gasket for this
delete was around. Perhaps I'll just stick with the trim. I don't really
want any leaks in the front.
Thanks for all the ideas guys
Karb
