Cracked 915 Drain Plug
I cracked the drain plug on my 915 trying to remove it a few days ago and the 17mm hex fitting is of little use now because the female end is flared. Is there an easy remedy or will I need to get a piece welded on to get a grip?
Makes me want a lift. I hate working under jackstands. I'm sure I'm not the first, but I didn't see anything in a search. thanx todd 86 coupe |
I wouldn't try anything but welding another piece on...Fact is these bastards are on tight, and there aren't a lot of tricks that would work effectively if you already flared the plug.
I would recommend removing the fill plug first if you haven't already, that way you're not up poop creek if you crack that one with the tranny already drained...
-Matt 1985 Targa |
Thanks, I've changed the gear oil on this car three times, but the last time I must have overtorqued
![]() I had no prob getting the fill plug off 1st ![]() thx again todd 86 coupe |
Never-Seeze on the replacement plug...but you've probably already thought of that one.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Autobahn Garage
Put some valve lapping compound on the allen bit, this will give you the grip you need to remove it, or drill a hole in the center of it and use a large ez-out to remove the plug
T Tanner 76, 911s w/ Webers 76, 914/4 57, Speedster |
Or put a piece of trimmed shim stock (your choice of thickness) into the hex hole and hammer in your hex allen socket. or wrap said shim stock around your hex allen socket and work into place.
Remove drain plug. Replace with new drain plug. Do not over torque.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Addicted to Racing
When replacing it, I would recomed what I did, which was to go to an early plug that has an external hex instead of the internal hex.
Ed
Check out the parts for sale: http://www.demonspeedmotorsports.com PCA National & NASA Instructor, NASA GTS & PCA GT Class Racer. See my list of current cars in my garage. |
OK ED...I've posted this many times before...just WHERE can you find such a plug that has a tapered 22 mm thread......looked forever at all kinds of places for this....as an archive search will show.
Inquiring minds want to know !!! - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Tapered thread as in pipe thread? I don't think so. I think the al. washer provides the necessary sealing, not the threads. Normal corrosion, heat and galvanic action supplies the remainder of the sticktion.
It's been a while since I've dealt with the tank drain plug. Years ago, I replaced it with a Fumoto ball-valve. I recommend its use. Sherwood EDit: My bad. My thoughts were somehow on the oil tank, not the gearbox. Last edited by 911pcars; 09-30-2006 at 02:51 PM.. |
I was wondering if there was an 'outie' version . . .
I've got the car gong to the wrench this week and I think I'll just wimp out and add this to the list. todd 86 coupe |
Scott
1984 Targa |
Not so...
The truth is out there.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
1984 Targa |
![]() BTW-This is a bad news picture - note the dog tooth.
Addicted to Racing
Here are a couple of part numbers. The first is the top fill plug the second is the bottom drain plug with magnet.
I just checked in the garage. I have 4 915's all of the mag case transmissions have the outty version, the alluminum case trans has the inny (my race trans is a 85 915 with early outty plugs) 999.064.007.02 999.064.008.02 Ed
For those of you with "outties," did you purchase them recently or have they been on your cars for awhile? My understanding is that the outties did exist at one time, but that they're NLA at this point.
1984 Targa Last edited by scottb; 09-30-2006 at 02:10 PM.. |
Addicted to Racing
I have a bunch of extra case parts, so I looked through them and it looks like I have two spare sets of plugs if anyone would like to make an offer.
Thanks Ed
Ed: You have mail.
1984 Targa |
Anyone tried ordering using those the part numbers show above? Dealer/other price?
Dan in Pasadena '76 911S Sahara Beige/Cork |
Dan: Given all of the comments over time about the Porsche parts being "innies," at this point I have to believe that the outties are NLA from Porsche, Pelican, etc.
1984 Targa |
