CV Joint rebuild help
I have an '88 Carrera and I am taking the CV joints apart for cleaning and boot replacement. How do I get the wheel side of the joint apart? I know it is integral with the drive shaft splines but there has to be a way to get it apart for cleaning.
Thanks, Bob |
Yes, the joint will come apart. You can repack the outer joint. But you can’t replace it. The nuances of this statement will be obvious once you dismantle a half-shaft.
Best tips I can provide...
So how do I get the outer joint apart?
Thanks, Bob |
if it's the same as my 85 then you must remove the outer nut in the hub, then the full axle will slide though to the inside, here's a pic from my manual.....
http://forums.pelicanparts.com/uploa...1187571739.jpg |
There's tons of posts on this. You need to remove the entire axle to get to the outer joint. I recentely replaced both boots and cleaned the outer joint by leavng the axle on and sliding the boots down the shaft. Messy but not too bad.
Otherwise you need a 3/4" breaker bar, a large galvanized pipe and a fat friend to break the axle bolt: http://forums.pelicanparts.com/showthread.php?s=&threadid=62514&highlight=joint+% 2Aassembly |
or an impact wrench :-) I have both drive shafts out of the car along with the transmission (clutch replacement). I figured I would change out the boots since it should be easy at this point. I guess I am having trouble removing the flange with a drift (removal item 4 in link). It is not budging, just getting beat to hell. Any ideas?
| All times are GMT -8. The time now is 07:11 AM. |
