Progress has been made. The cam boxes and internals are back on. Everything went really smoothly. No cam timing had to be done, because we found out that everything was still in spec when we put on the dial indicator.
http://forums.pelicanparts.com/uploa...1188844174.jpg Marco, thank you very much for coming out early on your day off! It means a lot. While I don't think I could do everything myself yet, I have a pretty good idea of what we did. The rest is down hill and the car should be on the road by Friday. SmileWavy |
Great Dave! I can't wait to see it run this Sunday.
(edited - wrong day) |
Dave,
Looking good. Thanks for the obligatory picture. One of these days, it will be my turn to drop the engine except I want to see how many SOCG guys can fit in a Porsche engine bay. Will see you Saturday, keep up the good work and I'll be the only one with oil leaks. Chris |
The last piece of the puzzle showed up today :D
Out with the old restrictive and in with the new-to-me euro premuffler. http://forums.pelicanparts.com/uploa...1188972119.jpg http://forums.pelicanparts.com/uploa...1188972190.jpg The cat came of with little resistance. I used a closed end 13 mm wrench and a 13 mm socket with breaker bar. Spraying a bunch of penetrant helped as well. Chris, Scott, I thought we are going on Sunday?? That's what the thread shows. Saturday is my buffer/safety day for my car! Anybody in the L.A. area wanna come out one of these evenings and help put the engine back in? It's much easier with at least two people. Dave |
Dave,
sorry for not having responded earlier to your PM. Unfortunately, I have been very busy since I returned from Japan. I ripped my carpet out from my staircase and have started to work on putting wood down. It's a long overdue project. I am not even sure if I'll make it to the GAF next weekend since I migth have to take off for Korea...... Grrrr. Hope you get it all done. When putting the engine back in the key is to be slow and to double-check many times that nothing is interfering when you join the two. For hookup just go through the list for what the engine/tranny packet needs to function. The most comon mess-up is the ground strap not being hooked up or tightened. Other than that it is pretty obvious if something is missing. Good luck and maybe we'll meet at GAF depending on what is going on with my travel plans. Ingo |
I hope things calm down for you and that you are able to make it to GAF! Dave |
Alright, engine is in, but still silent. I really should have made sure the the bung in the premuffler was the right size for the O2 sensor. Well, it's too small and I figured that out after Radu and I reinstalled the engine. Fortunately, we were able to get the premuffler back out with little problem. I will fix that little problem tomorrow and my 911 will be coming home tomorrow evening!!!
Here are two pics with the engine tin and muffler still off. http://forums.pelicanparts.com/uploa...1189151829.jpg http://forums.pelicanparts.com/uploa...1189151857.jpg Radu, thanks for coming out!!! It makes things easier and also helps to have two heads thinking on how to solve the little problems. SmileWavy |
i'm not much of a wrench, but Ican lift a 911...:D
you're welcome! |
I am sore and my left shoulder is really sore. Ever since messing up my right shoulder, I have become somewhat left handed. Dave |
That's cool, guys! So dave, what are you having done to fix your "bung hole" problem?
Bad news. Everything went together without a problem and the car fired right up. As Marco and I were warming up the car to check the oil level, all was fine. As I was leaving, the engine started to make a weird noise from the right chain box area. It is not the typical chains dragging over a trash can, but it sounds to me like the tensioner sprocket is hitting the box.
I will tear into the right box tomorrow (today) and see what is going on. I am disappointed and at the moment a bit pissed, but there is nothing I can do until things are opened up. A big :(!!!! |
Since I can't turn my mind off, here are two theories...
1) The tensioner failed and the loose chain is smacking the areas circled in yellow and red. http://forums.pelicanparts.com/uploa...1189236585.jpg 2) Somehow, the tensioner hyper-extended and it is forcing the sprocket, circled in red, into the ledge. See above for picture :) Other options are that a nut or bolt loosened and is causing things to rattle, but it was getting louder as the engine ran longer and became hotter. In my best pirate imitation - Arrrrrggggghhhhh!!!!!!!! Dave |
Only other thing I can think of, is that the tensioner is acting like a piston and jackhammering against the sprocket support.
I should add, that the noise went away during a bit of acceleration and on deceleration, but became louder as the engine warmed up. Oh well, it's all speculation at this point, I'll see what happened tomorrow. I will say that the euro premuffler added a nice sound. |
Bummer.
I hope you checked the cam timing 3 times. |
The right tensioner collapsed. Looks like I'll be ordering some new ones...
http://forums.pelicanparts.com/uploa...1189296057.jpg :( No metal in the oil. The engine is OK and that is a good thing. Dave |
I ordered two new tensioners and the related gaskets, nuts, washers, etc. My parents were kind enough to provide me with their Visa CC :). I don't trust the left tensioner and since I have to go through the cam timing steps again and have the muffler removed, I might as well replace them both.
Parts should be here mid week. Dave |
Wow Dave! When it rains it pours.
Good luck Dave!! I wish i can give you some insight, but i am only a tiny pea in a pod!!
Oh well...come see us at GAF.....
It's alive! My 911 is back home as of now. So far, there are no oil leaks, but we'll see what happens after the RPM needle is worked out a little ;).
Marco, thank you for everything. It's assuring to have someone that knows what he is doing. Last thing I need, is to cause a valve to introduce itself to a cylinder. It was a bummer to have the car back together and running, only to have to tear into it again. Now I have to record the mileage and note how many quarts of oil are in the car. I am surprised that the car is showing no smoke from the exhaust, now that there is no cat. Anyone wanna go for a drive :) Dave |
You're welcome; it was my pleasure. And thanks for the beer, too. Fat Tire goes a loooooong way in my book.
PS: Wanna race? :D |
Congrats, Dave!! Get that car down here so we can take a run up to Palomar. One of the best roads I've been on yet.
Btw, just because you don't have a Cat doesn't mean it's going to smoke. Very light brown smoke usually means unburned fuel, which is usually a result of a mis-adjusted fuel system. You will get that...smell...though. So, how do you like the setup, anyway? |
Marco, remember, you only have 4 lug nuts per tire at the moment. Maybe I could use that to my advantage :D.
Scott, will do, but it'll have to wait a few weeks. I'm broke. Regarding smoke, I still am wary of the 227,xxx mile valve guides ;). Marco and I "dragged" for a minute, when suddenly, my gas peddle went soft :eek:. the ball joint popped off at the tranny - pulled into a gas station and fixed it. My car has a noticeable gain of low and mid end boost and the throttle response is quicker. I saw half of the Valley's police force on the way home, so I did not get to explore things much. The sound is a bit more throaty as well. Something was going down as I went home. All of the side streets off White Oak were blocked by cops and one heli was lighting up the area. Dave |
Hey Dave.
Good to see you're up and running again. Tomorrow afternoon. Bob's Big Boy, Toluca Lake. German Invasion. More details on the "Mulholland RSR" thread. |
