Snoozy Speedo
My 86's speedometer has taken to not moving until I get to about 35mph at which ponit it wakes up at seems to operate normally. Anyone else have this? Is it a symptom of something I should maybe look at?
thx todd 86 coupe |
(the shotguns)
mine does the same. i believe it is dirt in the line. mine also bounces at various speeds.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
I advise to drive way over that as much as possible
Jim 911 Mint Green "RSC" #mintgrun 911 Gentlemen's Rallye 85 Carrera GP White 2012 C63 AMG Mars Red |
Yeah my '85 does this, surprisingly the odometer moves normally whether the speedo needle budges or not. I have no idea why. What does dirt in the line mean, I figured that it was an electrical glitch. Is there anything that I can do myself? Thanks to whomever can advise on this.
Scott
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
Probably need to replace the speedo sender mounted on the tranny. Mine did the same. I replaced that guy (about $100) and it works like a champ now.
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Did you notice berettafan has a 1970 2.4? His car has a cable in a tube with a mechanical differentiator.
In 1970 you could buy nand gates, nor gates, resistors, transistors and capacitors and that was about it. A speedo would have occupied the space of a radio.
Rick 88 Cab |
(the shotguns)
oops, forgot you fancy modern guys might not have cables.
Maybe it operates on Tubes
Racer
My 87 does this. I don't think it is the sender. If I give the speedometer a light "tap" with my finger at slower speeds, it wakes up and registers. I think it must have dirt inside or something, and when the electro-mechanical motion gets strong enough (like at about 40 mph) it overcomes the stickiness and moves.
Preston Brown Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn) 1965 356 C Coupe | 2010 F250 (support vehicle) Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera |
Same story on my '83. A light tap on the bezel wakes it up or a small bump in the road will do it also. I know there are threads on disassembling various gauges but I haven't seen one that addresses this specific issue.
Guys, Mine was doing this as well. It was very strange. A light tap would get it working but when I replaced my sender it work all of the time.
Very strange.
911 addict
On my 87 Carrera it wakes up at 20mph. Odometer seems to be normal though.
1987 Carrera Cab Toyota Landcruiser 500SL |
My 82 VW Vanagon does the same - although I probably spend a lot more time below 30mph than you guys do...
1970 911 T 2004 Carrera 4S |
I posted a thread on my speedo problem a while ago and got little response so I should mention it again here. My '76 speedo suddenly won't register higher than the low 50 MPH range no matter what speed I am actually going. It doesn't not act arratic up til that speed, needle movesd smoothly.
Does anyone know the cut off year between an electrical and a cable operated speedo? I think it might BE '76 is the last cable year. Is this problem more likely to be the cable or the guage and what will it cost to fix it?
Dan in Pasadena '76 911S Sahara Beige/Cork |
