Spark plug gap question
Hello
Changing the plugs yesterday, I noticed that the manual specifies plug gap of 0.024. The WR5DC+ plugs (recommended by PP and others) have a gap of ~0.032. I assume this is acceptable or that a note to re-gap plugs before installation would be made somewhere... Stock 2.2t engine with bosch distributor/crane ignition, if that helps. One of the old NGKs I pulled out had a badly cracked insulator. Yikes. |
I would use the factory spark plug gap specs unless your car has an MSD box instead of the factory CDI box.
.028 - .032 should do you fine, NGK BP6ES or BP7ES depending on your operating conditions.
Mine are supposed to be .028, I have them at .035" and love it. No more gas smell at idle and no little backfires when letting off the gas.
With an upgrade to an HEI distributor cap/ ignition cables, my 86 3.2 has no problem firing a 0.060" gap.
Hows that working for you? I still have the bookmark somewhere. |
That's right. An HEI Jeep Cerokee cap and rotor.
I have to admit that it's probably the most reliable ignition upgrade that I have ever had on my 911. Seems like I never have to worry about ignition issues ever again even after degreasing/hosing it off, it never skips a beat. Nothing like having the reliability of a domestic with the performance of an exotic. Whoever said "you can't have your cake...."? Cheers, Joe |
So your using the coil pac built into the cap?
I did this method on my 87 Wangler using a GM HEI. Sounds like a nice upgrade for the Porsche. |
Sorry for the dirty engine, but as you can see this was before I installed the waterproof HEI cap. Now I don't worry about hosing my engine when I degrease it like I do on my domestic cars. http://forums.pelicanparts.com/uploa...1152081493.jpg http://forums.pelicanparts.com/uploa...1152081550.jpg http://forums.pelicanparts.com/uploa...1152081603.jpg http://forums.pelicanparts.com/uploa...1152081656.jpg http://forums.pelicanparts.com/uploa...1152081707.jpg HEI cables http://forums.pelicanparts.com/uploa...1116271542.jpg http://forums.pelicanparts.com/uploa...1116278075.jpg http://forums.pelicanparts.com/uploa...1157659429.jpg http://forums.pelicanparts.com/uploa...1121574427.jpg Water cooling. |
| All times are GMT -8. The time now is 11:56 PM. |
