Need help, AFM rough settings
Guys, just replaced the inlet manifold gaskets on my Carrera 3.2 1985, but I need an approximate setting for the AFM mixture adjustment screw just to get me close so I can drive the car to work and fine tune it on the gas analyser. The gaskets had sucked in that badly that the mixture/idle is now well out of adjustment.
Any help appreciated. ps have tried the search function to no avail. Cheers Mark |
It is a federally mandated setting - however -
IIRC - I found my settings at 3 complete turns in. Unscrew it all the way until it stops loosening, then tighten it three whole turns in. I marked my little allen as it went in with each two turns. This way, I didn't have to go through this each time. Now I can simply put the allen key in and see how far I moved the screw. I unplugged my O2 sensor, connected my DVOM to the O2 sensor and chased it until I found my O2 sensor bouncing between rich and lean. It was rich ( > .8 volts ) with the O2 disconnected. My Gunston (sp?) reads 2.2 with O2 disconnected now. But I still have a stumble on the initial acceleration. Good luck. |
Thanks Nick, I'm in the UK so the CO limits are are a little more relaxed than in the USA. ie <4.5% CO and <1200 ppm on hydrocarbons with no Lambda reading as the car doesn't run a cat. I was screwing the adjustment all the way in ie clockwise until seated and then screwing anti clockwise 2 1/2 - 3 turns out so I'll try your method. My adjuster does screw all the way out so to clarify your advice I unscrew it all the way out then in 3 turns?
Mark |
Unscrew it all the way out then in 3 turns. That's about where I am at.
good luck. |
Thanks Nick, managed a tickover of sorts and was able to drive the old girl to my work and fine tune on the gas analyser, job sorted.
Mark |
| All times are GMT -8. The time now is 02:01 PM. |
