Targa hoop
hello people, its my first post so please be gentle, I have just started the resto of my 73 targa, in a prvious life someone had done there best to make it look more modern, and had blacked all the trim etc, I would like to restore the hoop to its original finish, i have looked hig an low on instructions on how to remove but knowing how fragile the rear glass is i would like to get as much info as possible before proceding,
so if any one has done this before i woulb be very gratefull for information, will post some picture of work in progress
and will also need some help with parts
Volkstuning
Old 05-14-2007, 01:58 AM
Use the search function...I remember seeing some posts on removing paint from targa bars in the past. Seems to be fairly straight forward.
Check these out:
Targa bar cover - To blast or not to blast?
Question for those who've refinished their own Targa bar...
Good luck.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 05-14-2007, 05:37 AM
70SWT's Avatar
You will find that removing and reinstalling the targa glass is a major hassle. I am in the same boat; my 72 was the victim of a black-out updating project in the late 1980s and I also need to change the targa bar back to the stainless appearance. I am going to do it without removing anything from the car, unless I run across the items needed to convert the car to the soft rear window.
2018 911 Carrera coupe
1972 911T targa
Old 05-14-2007, 05:57 AM
Yes, but it can be done.
The rear window glass is anything but fragile. Short of dropping it on a concrete floor, it's tough to break.
Volkstuning, if all you're doing is removing the Targa bar cover for polishing back to original, you'll not be getting into the rear window at all.
Brian
Old 05-14-2007, 06:03 AM
It'll be legen-waitforit
stealthn's Avatar
For those who did remove and repaint their Targa bar skin, did you replace/require any parts during the removal/replacement? Sounds like a good time to replace the rear seal, and I was wondering about the read (above the rear glass) piece of black rubber/plastic around the skin; did this need to be replaced?
Thanks in advance.
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 08-07-2007, 06:51 PM
hello again guys, well the car has been painted it has been murder trying to get all the parts and right information (spain is a real B***H sometimes despite the good weather,
we are trying to fit the rear screen with new rubeer seal etc and also trying to fit the moldings as well, well the moldings will not stay in the rubber,
can anyone advise what the best method for this is? i could really do with some good advise as the glass fitter wants to hold his hands up and Say that it cant be done or its to difficult etc etc,
i am going to try and help him do it so i would appreciate as much information as possible
many thanks
Old 08-21-2007, 04:36 AM
Ray_G's Avatar
I am sort of in the same boat, my targa bar was blacked out, I stripped it and found that it had a lot of hail damage and putty before paint. So it is useless to try to restore. But I have a later model bar that was originally painted, I have it stripped, but it was never polished and or brushed. Does anyone have any ideas how to give it an original appearance? From what I can tell they look like they were polished then brushed? Tips or advice anyone?
76 911S Targa
An ex F1 driver, and Porsche fanatic (my stepfather) once told me that if you listen very carefully on a quiet night you can actually HEAR Porsches rusting in the garage!
Old 08-21-2007, 06:30 AM
durn for'ner
livi's Avatar
Welcome to the forum and yet another European member!
Estepona! I have spent many a Christmas and Easter in Nueva Andalucia/Puerto Banus the last twenty years! I really envy your climate and the road surfaces are so smooth. Never driven a Porsche there, must be great.
Well, honestly, last time, a year ago, I found the main road going west from Puerto Banus had really started to crumble from all the traffic.
Markus
Resident Fluffer
Carrera '85
Old 08-21-2007, 06:44 AM
I think your approach should be to remove the cover from the car and use paint stripper to remove the paint.
Then start with a 400 grit sand paper and sand lengthwise to get the brushed appearance you are looking for, if the scratches look to big just switch to a finer grade of paper or use steel wool until it looks brushed.
Once sanded you could probably finish it up with a acrylic satin clear-coat, you should test the clearcoat first to see how it reacts with the metal.
I haven't tried this but have been considering it.
Or you could polish it using a buffing wheel and rubbing compound then it would be smooth and shiny.....Ive never seen that done, it would probably be original.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 08-21-2007, 08:54 PM
AFCuk's Avatar
Hi
The hoop is held on by 4 bolts under the wheel arch, up high next to the door slam pannel.
There are also 12 or so screws that hold it in place under the rubber seal.
Take this lot off and just pull and wriggle it off.
Paul
83sc targa BBT
Old 08-22-2007, 12:14 AM
okay guys success the trim is now in the rubber and all is back on the car, i cant really add anything that will make the job easier for any body else apart from the following:
its not a 5 minute job, so do it when you have no urgent appointment's or have to be somewhere, it takes patience
try and get some extra hands as this helps keep the trim in place and balance the screen as you push the trim in and try to make sure the rubber does not come of
start at the corner of the seal, and work you way back to-wards the rear of the seal or the center where the clip will be fitted at the join, its a longer distance before you have to start shaping the trim to the curve and it does not pop out
put the rubber on the screen and then fit the trim and the put screen into position
again as many hands as poss here to apply pressure and again stop the trim popping out,
we finally got it done after 4 hours and it was worth it, even the glass fitter admitted afterwords that it looked great and was worth the effort,
and now ladies and gentleman for my next problem,
how do you remove the dashboard top??????
since this needs to be replaced or trimmed we want to this before replacing the front windsceen
again all help and advise welcome, i have found taken out all the screws along the front lip and have gentle leaver the the dashboard away but it seems to be held down in other places, does the glove box and gages have to come out?????
thanks again for all the post
Old 08-22-2007, 12:28 PM
