URO Turbo valve cover review
I have just replaced my leaking warped valve covers on my early 911.
Well made. Looks great and a perfect fit. Its just an aluminium casting with a nice machined face so what can go wrong. I would certainly give a thumbs up for these. Next oil change or valve clearance job.
Lyndon
Old 07-01-2020, 11:52 PM
iamheretolurk's Avatar
Lyndon, love this. I was debating buying a set, given how cheap they are compared to others on the market. What did you do about your uppers? Did you keep them stock?
Old 07-02-2020, 07:18 AM
Stock uppers. Just gave them a sand on some glass.
Old 07-02-2020, 07:22 AM
Pelican Parts Vendor
UROParts's Avatar
Thanks for sharing Lyndon, appreciate it!
The URO Parts turbo-style lower Valve Cover has a SurTec 650 passivation treatment for corrosion resistance (which darkens the surface a bit and gives it a hint of rainbow hue), and is available from Pelican here: 930 105 116 05 (they're working on adding a product photo).
Here are results of a similar SurTec 650 treatment after 336 hours of exposure testing, compared to 120 hours without treatment and 336 hours with yellow passivation.
Photo credit: Suresh Metal Finishers Pvt. Ltd.
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2
Old 07-02-2020, 09:01 AM
creaturecat's Avatar
fortunate to have a company step up to the table.
nice!
Old 07-02-2020, 11:07 AM
gtc gtc is offline
abides.
gtc's Avatar
Looks nice. And affordable enough to have a spare set around to speed up valve adjustments (clean them later at your leisure)
Graham
1984 Carrera Targa
Old 07-02-2020, 12:55 PM
franklinstower's Avatar
Hey URO dude,
Do you have a recommended lower gasket to go with your turbo style valve cover? Seems like the perfect opportunity to supply a "leak free kit"?
'78sc coupe / 89 Westy - EJ25 frankenmotor
Old 07-07-2020, 02:21 PM
Red Line Service
Marc Bixen's Avatar
Originally Posted by franklinstower View Post
Hey URO dude,
We recommend, with late turbo style covers, Wrightwood racing Gray graphite upper gaskets, green lower, no silicone bead, new washers and nylock nuts(wrightwood racing kits come with the best hardware, the washers are hard alu.). Then torque he uppers to 15 ft/lbs, the lower to 18ft/lbs. They'll never leak:
https://www.pelicanparts.com/catalog/SuperCat/0801/POR_0801_ENGCYL_pg1.htm#item1
Wrightwood Racing Valve Cover Gasket set
930-105-195-02-98-INT
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 07-07-2020, 05:45 PM
