emac's Avatar
Valve Cover Question
Just changed oil and I now noticed that I have a slight drip from the exhaust gasket. She is a 81 SC and new gaskets are in order. I have heard that you can jack up the car and the oil will drain to the other side without having to drain out all of the oil. If so, how high, and how much oil will I lose?
Thanks to all in advance.
Ernie 81 SC
Old 08-22-2007, 04:47 PM
Valve Cover...
Ernie,
High enough to be able to remove the rear tire. Do one side at a time and you'll have minimal oil loss from dripping. Clean the mating surfaces very very well. Good luck...
Tony
Old 08-22-2007, 05:24 PM
slodave's Avatar
Check to make sure your valve covers are not warped. Even the turbo covers can warp over time. Mine did. A thick piece of glass works well as a flat surface.
Dave
Old 08-22-2007, 05:29 PM
Zeke's Avatar
Dave
Meaning as a reference and a place to use wet or dry silicone carbide sandpaper to get them flat again. I use kerosene or similar for lubricant. Cuts fast.
Old 08-22-2007, 05:48 PM
Evolved
Mo_Gearhead's Avatar
And do NOT over-tighten (nuts) when re-installing them.
Don't fear the reaper.
Old 08-23-2007, 07:59 AM
