Valve Cover Question
Just changed oil and I now noticed that I have a slight drip from the exhaust gasket. She is a 81 SC and new gaskets are in order. I have heard that you can jack up the car and the oil will drain to the other side without having to drain out all of the oil. If so, how high, and how much oil will I lose?
Thanks to all in advance.
----------------------------- Ernie 81 SC |
Valve Cover...
Ernie,
High enough to be able to remove the rear tire. Do one side at a time and you'll have minimal oil loss from dripping. Clean the mating surfaces very very well. Good luck... Tony |
Check to make sure your valve covers are not warped. Even the turbo covers can warp over time. Mine did. A thick piece of glass works well as a flat surface.
Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Evolved
And do NOT over-tighten (nuts) when re-installing them.
Don't fear the reaper. |
