-   -   glue, glue, I need glue... (http://forums.pelicanparts.com/porsche-911-technical-forum/363581-glue-glue-i-need-glue.html)
brownbutter 08-24-2007 07:42 AM
or part number for the adhesive tape for the threshold Rubber/Plastic/PVC Strip for the inside body of the door jam.
thanks
Porsche_monkey 08-24-2007 09:48 AM
Contact cement?
Rot 911 08-24-2007 09:48 AM
Just use plain ole rubber cement.
scottb 08-24-2007 10:53 AM
I use this stuff called "The Welder" from OSH. It is the strongest contact cement I've ever seen.
daepp 08-24-2007 11:18 AM
How about the rubber "handles" on the turn signal and the wiper switch. They're glued on - as I replace them, anyone have a glue suggestion. It must be a strong bond.
Sorry for the hijack.
Porsche_monkey 08-24-2007 11:18 AM
Two part epoxy or urethane (gorilla) glue.
scottb 08-24-2007 01:35 PM
Gorilla Glue is amazingly strong. Just be careful when using it; it expands as it cures.
My favorite two-part epoxy for strength is JB Weld. Great stuff and incredibly durable.
herr_oberst 08-24-2007 03:08 PM
I never knew you could use gorilla on anything but wood - does it hold? Do you still need to moisten one surface? Are these questions answered on the label?
scottb 08-24-2007 03:34 PM
According to the website, it can be used on a variety of surfaces, including metal, glass, ceramic, concrete, etc. The trick is to roughen smooth surfaces so the glue has something to "bite." And, yes, you still have to moisten at least one surface. The moisture serves as the catalyst for the glue. In fact, I recently discovered that a five year old bottle of this stuff had hardened to a rock due to, I guess, moisture in the air seeping into the bottle (even though it was closed tightly).
herr_oberst 08-24-2007 06:18 PM
The things this blog can teach . . .
911 in SC 08-24-2007 06:45 PM
When I first purchased my Carrera, the door rubber around the opening was 'loose' and I used Gorilla Glue on it. No issues so far. All I did was spread it on the rubber and put it in place. No problems at all.
I've used Gorilla Glue on ALOT of things, and they ALL seem to work. Great stuff. Anyone ever use the Gorilla Tape? What's it like?
Sorry for the OT, but Gorilla Glue really does work well.
Porsche_monkey 08-25-2007 04:40 AM
Gorilla vs duct-tape is like duct tape vs masking tape. An order of magnitude improvement.
911 in SC 08-25-2007 05:47 AM
So the gorilla tape has stronger adhesion than duct tape? WOW. That'll be impressive. Thanks!
Porsche_monkey 08-25-2007 06:14 AM
Once you use it you will never buy the silver stuff again. Unless you want to remove it some day...
