Porsche Crest G50 clutch question
I have just had a new PP, flywheel and metallic clutch disc installed in my 87 track only 911. At the point of drive-line engagement (clutch disengagement) in first gear, I am getting a fairly loud momentary squeal. Almost sounds like a metallic version of momentary tire lockup. I can make it happen in second a bit by mis-matching the revs/feathering the engagement, but otherwise all other gear transitions are quiet. Drive-line locks up nicely as soon as the clutch is disengaged in all gears - no slipping. New TO bearing and guide tube. Could this be a wear in situation or is that not really a factor with a racing style clutch disc? Thanks
Old 08-25-2007, 03:18 AM
don911's Avatar
When I had a Kennedy Engineering PP and non OEM clutch (don't remember what clutch) I had the same thing. It only seemed to happen when I had to slip the clutch on a hill or something. Don't know what was causing it. It may be normal with the type of clutch/PP.
btw - the clutch is the coupler in the system. You're engaging the clutch when you're hearing the squeal.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 08-25-2007, 08:20 AM
this may not be relavent... but the exact thing happens on my Volvo after I replaced the clutch... when I replaced the clutch on 89 911 all seemed perfect and still is...
Old 08-25-2007, 09:47 AM
Diss Member
Quicksilver's Avatar
What kind of clutch facing does your disk have?
I have the Kennedy light weight pressure plate with a Sachs sprung dub disk and the thing doesn't make any engagement sound. (Love the combination...)
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 08-25-2007, 10:07 AM
Porsche Crest
Patrick Motorsport, metallic, bronze sintered I think. Made for racing durability. On or off,any slipping and you get a "chirp".
Old 08-26-2007, 05:57 AM
