-   -   RSR vs IROC (http://forums.pelicanparts.com/porsche-911-technical-forum/363765-rsr-vs-iroc.html)
911 tweaks 08-25-2007 12:20 PM
RSR vs IROC
can those in the know tell me as much as possible the differences in these 2 car iterations that Porsche made. Even the yrs made, colors offered...
Thanks alot as I am trying to see which way I want to go on an SC.
Thanks! Bob
Bill Verburg 08-25-2007 12:35 PM
An IROC is a RSR built to the specs of the series of that name.
They share the same serial # sequence and most if not all major components
911 tweaks 08-25-2007 02:03 PM
thanks Bill. Can you recommend any good places to go read up on the specifics of both, specs on engines, mechanicals, photos, yrs produced...ya de ya da
Bill, would it be more economical (less $$) to make an "RSR appearing tub" and put in a stock or slightly modded 3.6?? Would you go with coil overs?? Would you use 930 floating brake set up or something different?? I would like A/C in the car but to not tax the engine, thus 3.6?? Would you use an SC tub as a starting place or go the "zuffenhaus c2 to RSR" that is what Keith is doing in NC??
Basically, I am wondering what is the least expensive way to have a RSR looking car, A/C, perform like a RSR did, and have some modern comforts so you can drive it on a 95 degree day w/ 70% humidity, and the car still cranks!! 95% street... 5% de
Thanks! Bob (Bill, is this similar to what you have built before??)
911 tweaks 08-25-2007 02:09 PM
my comparison on the engine is the 3.6 as described above vs. building a 3.0 RSR which I am told will run $15-20k... and if I tweak the 3.6 slightly, I can get it to ~ 300hp way less expensively and maybe a more reliable engine??
Bob
jjwood 08-25-2007 02:31 PM
The IROC was essentially the same bodywork as a '74 Carrera RS (9 &11 x 15" wheels), whereas the '74 RSR had much larger "ducted" flares (10.5 & 14 or 15" wheels). The confusion arises because the '73 RSR (long hood + ducktail) had essentailly the same flares as the '74 RS.
skipdup 08-25-2007 02:40 PM
That's how I understand it too. IROC had '74 3.0 RS body with '74 3.0 RSR engine, suspension, brakes, etc.
I've been trying to find THIS book by John Starkey, as I hear it does an excellent job chronicling R's, RS's and RSR's.
I may have found the author and have emailed him emailed him about getting a copy. If I have success, I'll let you know.
- Skip
boba 08-25-2007 02:55 PM
The RSR can be divided into 2 groups the 2.8ltr '73 longhoods and the 3.0ltr '74 G body cars (short hood). The '73 2.8 ltr were MFI high butterfly, 9&11x15 Fuchs. The '74 RSRs were 3.0ltr MFI slidevalve, the IROC cars also ran 9&11x15" Fuchs. The RSRs had the wider flairs and 12&14x15 centerlock mag wheels. In later years the cars came with BBS 3 peice wheels.
early RSR (note oil door, first RSR were built on 72 tubs)
http://forums.pelicanparts.com/uploa...1188078756.jpg
9x15 and 11x15
http://forums.pelicanparts.com/uploa...1188078814.jpghttp://forums.pelicanparts.com/uploa...1188078832.jpg
'74 RSR
http://forums.pelicanparts.com/uploa...1188078888.jpg
12x15 and 14x15
http://forums.pelicanparts.com/uploa...1188078934.jpghttp://forums.pelicanparts.com/uploa...1188078949.jpg
skipdup 08-25-2007 03:01 PM
I just got a responce from John Starkey...
Hello Skip
Yes, I'm the author-It's long out of print. Try the internet.
I am re-writing the book and hope to have it out within 6 months.
Kind regards
John Starkey
- Skip
Bill Verburg 08-25-2007 03:04 PM
The '73 IROC cars were officially Carrera RSR 3.0 and were the same as the '73 RSR w/ 9 &11" flares, 917 brakes etc. except that they had the the later '74 up style f/g bumpers(this was the first intro of the '74-89 style bumper cap.
the chassis #s were 911.460.****
15 IROC RSRs were supplied in this configuration to Roger Penske for the series
The original cars had the '73 ducktail, but they were soon changed to the more efficient later whaletails.
engines were 316 ± 3hp, high butterfly injection identical to the other RSRs campained at the time
the 53 '74 3.0RS's were a derivative of this car, the RS was a homologation special, and had a detuned 230hp version of the RSR engine. Bodies and other running gear were identical.
the '74 RSR did indeed have the wider 10.5" & 14" fenders w/ centerlock wheels
these '74 RSRs had 330hp@8000 initially lter bumped to 345hp
A much more informative book is Starkeys "From R to GT3R'
Bill Verburg 08-25-2007 03:14 PM
Starkey
Matteos car is an IROC replica, yes, it wil be a lot cheaper and streetable w/ 3.6 power. A true RSR engine is not streetable.
as to the tub you have 3 choices
'73 and earlier
'74 -89
'89 -94 964
each has plus/minus depending on what you want to do.
If you want a 6 spd start w/ a 964 tub
if you want rust protection 'late 911 is best
if you want lightest weight '73 and earlier.
Bill Verburg 08-25-2007 03:15 PM
Bob
it isn't cheap to get 300hp form a 3.6 either
the 3.6 does have the advantage of very streetable torque, this is what you really want.
Bill Verburg 08-25-2007 03:18 PM
to be absolutly correct it is the otyher way around, the IROCs came first, then the 3.0RS
'the 74 RSR did have the bigger vented fenders
the '74 RS looks like an SC/Carrera
Bill Verburg 08-25-2007 03:20 PM
- Skip
Again IROC was first, 3.0 RS followed and did use the same bodywork and running gear, but the IROC had the 300hp 3 liter introduced in late '73 for the '74 season ,'73RSR engine not the more powerfull '74 RSRS engine
boba 08-25-2007 03:34 PM
Bill is as usual correct. The IROC was between the 2.8RSR and the 3.0RSR with attributes of both. The 3.0ltr with the high butterfly, the 5 stud hubs with the g bumpers, early flares.
As time went on many of the cars were updated and when looking at photos from the day you will see many of these cars with this evolution taking place not to mention the team developed changes.
Bill Verburg 08-25-2007 03:37 PM
the chronology starting w/ '73
2.8RSR
3.0RSR
IROC
3.0RS
'74 3.0 RSR
after that it all went downhill when the turbos took over;)
cfc 08-25-2007 05:59 PM
Try Reading The Mucho Articles That Have Been Written On The Subject .
911 tweaks 08-25-2007 08:49 PM
Thanks Bill and others!! Great info here to read up on.
So to wrap up, I will read Starkys book and the new one coming out in 6 mos... in the interum, can you guys give me an overview of what is needed and the costs to make a 3.6 put out 300hp and are we talking f/w or wheels when the hp # is generally thrown about. I know that ~10-20 hp is lost through the drive train in getting to the wheels. I just want to understand the answers correctly.
Bob
Bob
gumba 08-25-2007 10:31 PM
check out a book called "the Porsche 911 and derivatives by Michael Cotton" It has a series of "factory photographs illustrating the stages of the development from the normal 911 2.7 through to the turocharged 2.1 Carrera. Shows a shot of the car and a shot of the different components used on that car. Cars include Carrera RS, RS3.0, RSR3.0, and the turbos. I think I bought this book in the early 80's. The IROC cars look like they are based on on the competition RS3.0 cars.
Walko 08-26-2007 12:47 AM
[QUOTE=skipdup;3445410]That's how I understand it too. IROC had '74 3.0 RS body with '74 3.0 RSR engine, suspension, brakes, etc.
If you are after this book let me know I can still get my hands on it. I know there was about three copies left.
Michael
eimkeith 08-26-2007 05:48 AM
Walko, I am also interested in a copy. Can you obtain one for me?
(and still looking for the German Carrera RS book, as well)
