Kolibri
Stud removal ! HELP !
Hi guys/gals,
It's been a while since I've been in here. School/family/ work, you know the drill. Anyways, after 5 sets of carbs, I learned my lesson and bought PMO's. Yeah, it hurt to pay that bill.. Anyways, I am installing the insulator blocksm which requires r/r of the intak manifold studs. 10 out of 12 nearly fell out. The last two, on cylinder number one are stuck. I soaked them in Pb for a week, tapped them with a hammer 100 times. Tried the double nut again today, and no-go. I am actually stretching/deforming the threads ont he stud. I even used a butterfly impact wrench for 10 minutes hoping to crack the death-grip on the threads. What's next? Butane torch? Vice-grips? Drill em out? So close to having a running car, yet so far away. MIchael
1942 VW Kübelwagen 1940 Zündapp KS 600 1941 Zündapp KS 750 1975 Volvo C303 TGBII 1967 Honda S90, 1975 CB550 |
"O"man(are we in trouble)
I'd try heat. Metals will expand and contract at different rates.
Remember
Get your double nut setup all ready to go then heat the head around the stud for a minute or so,
try to move fast after the heat is removed, the head will dissipate the heat quickly. I'll bet it breaks loose. Good Luck
Gary 1975 911S G50 3.5 Twin Turbo |
These do the job, when used with an impact wrench...$pendy for the full set, but handy if you work with studs...
http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=10349&group_ID=1247&store=snapon-store&dir=catalog
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
THE IRONMAN
Just watch yourself if you choose to drill it out...a bkn easy out will be pita to remove from the unit...
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
Mocha BAP
Mapp or hotter. Butane / Propane won't cut it.
Scott 71 911T Coupe 3.0 Looks stock 79 911SC Coupe 3.2ss Nothing stock 02 996 C2 Cab Mostly stock 06 955 CTTS Super P!G |
Kolibri
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=94640
This did the trick in 3 seconds and for $3 on sale. This is the first tool from Harbor Fright that I have ever been 100% satisfied with. FINALLY, something in that shop did something right. thanx
Kolibri
LOL, check out Staylo's avatar! YES!
