rbuswell's Avatar
Porsche Crest Vacuum leak parts list
A shop that worked on my very straight '82 SC told me that they couldn't get the CIS to adjust because it has vacuum leaks. Before I take the injection system all apart, I figure that I should have everything I need to repair it. I don't believe any of the parts that would contribute to this problem have ever been replaced so I'm planning to replace everything. Here's my part list so far:
6 - Rubber intake sleeves
6 - Injector O-Rings
6 - Injector Sleeve O-Rings
6 - Injector Sleeves
6 - Intake manifold gaskets
1 - Throttle body mounting O-Ring
1 - Airbox to sensor housing gasket
Can you fellow Pelicans think of anything I may have missed?
1982 911SC Coupe (Zinc Metallic w/ Dark Blue interior)
1987 924S (Black on Black)
Old 08-26-2007, 06:11 PM
Scott R's Avatar
Vacuum lines to the distro, vacuum line to the AAV, vacuum line to the cruise unit. Replace rubber lines to the brake booster, and the o-ring at the booster to MC connection. Check for cracks on the under side of the air boot, check for cracks in the AAR/AAV/Decel circuit. Replace the crush ring on the brake booster line to airbox nipple, replace the o-ring on the cold start valve. Clean the throttle body and check for leaks on the idle bypass screw. Also may want to check and replace the line form the air boot to the oil filler neck, it can crack and leak as well.
EDIT: If and when you get done, if you want to borrow my Gunson CO meter to set your mixture let me know, I'm not far form Castle Rock and would be happy to loan it to you.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-26-2007, 06:26 PM
rbuswell's Avatar
Fabulous list
Wow, Scott this is great! Sounds like I'm going to be pretty busy buying, checking and replacing. And yes I would like to borrow the CO meter when I get it done.
Old 08-26-2007, 06:37 PM
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-26-2007, 11:20 PM
Do you have a pop-off valve? That's probably the most common vac leak. Check the seal, make sure it's closed tightly.
Old 08-27-2007, 03:44 PM
rbuswell's Avatar
Porsche Crest Interesting that you bring that up
Mine was actually sitting in the bottom of the airbox when the mechanic opened the airbox. After seeing that, I determined that the design of the base of the valve is really supposed to be flat on the airbox contrary to Wayne's picture in the 101 book. I ground down all the fins in the airbox around the hole so the the valve could sit flush, really roughed up the two surfaces and then mounted the valve with a generous quantity of JB Weld. It ain't going anywhere now. Car still runs like crap however. But at least that valve is in there to stay. And the seal seems very good on the valve flapper.
Old 08-27-2007, 04:45 PM
rbuswell's Avatar
Porsche Crest Tried to Google it by model no
Originally Posted by RoninLB View Post
Ronin:
I tried to Google this by model number and nothing came up. What company makes it? Other similar units cost from $300 to $400. I'd need to be careful that I don't spend more chasing down the leak than it would cost to replace everything.
Old 08-27-2007, 04:59 PM
Jim Williams's Avatar
And don't forget the airbox itself. They can leak around the seam. Looking for the airleak with a propane bottle might save you some money in the long run, unless you just want to do preventative maintenance by replacing every possible thing that might be leaking........
The propane test has been covered on the forums. Try a search, and if you can't come up with something, post back to the thread and someone will help out.
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 08-27-2007, 05:34 PM
You may consider new Hose clamps for the sleeves, its good to have one or two on hand or replace them all.
+1 on the Air box as well, if the pop off was installed wrong then a backfire could have cracked it.
Old 08-27-2007, 08:56 PM
Originally Posted by rbuswell View Post
Ronin:
that model is from Snap-On.
similar units from OTC etc.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-28-2007, 01:58 AM
