Midwest R Gruppe
t6dpilot's Avatar
Pertronix Ignitor in an Early Car - Opinions Please
i would love to hear from anyone who has an opinion on changing your ignition from points to Pertronix Electronic Ignition. I am considering doing that, but want to hear from anyone who has experience first. Thanks.
Scott
69E Coupe 2.2S LtWt
73.5T Coupe
Old 08-21-2007, 01:42 PM
moneymanager's Avatar
Don't fall for any silliness that you'll have more power. Nothing remarkable happened to the car when I installed a Pertronix, though the tach on my car used to begin to misbehave when the points aged and the Pertronix fixed that.
Old 08-21-2007, 01:47 PM
Autobahn Garage
It's easy to install, and you will toss it in the trash when it goes bad. Stick with the points
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 08-21-2007, 01:49 PM
Does it make it easier to adjust timing? Setting dwell looks difficult, although I have never done it, I hesitate because of that.
1970 911 T
2004 Carrera 4S
Old 08-21-2007, 01:52 PM
barney911rs's Avatar
As a data point, I've had one on my race car for years, no problems. YMMV
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 08-21-2007, 01:57 PM
We've installed hundreds of them and their MTBF is less than 2%. I love 'em,...
No more HP, but much steadier timing and smoother running.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-21-2007, 02:36 PM
Type911's Avatar
Hi Scott,
Made the Petronix switch 2 years ago after realizing the art of adjusting points was not something I wanted to mess with. No problems to date.
Did my car feel any different than your T w/ points when you drove it in July ?
2021 Spyder
2019 Carrera T
2007 911 GT3
1973 911E
RGruppe #295
Old 08-21-2007, 02:53 PM
Bug Eating Member
frogger's Avatar
Early car running a pertronix ignitor for nearly 5 years with no complaints.
Old 08-21-2007, 02:56 PM
Same here, 2.7 S-spec motor running with pertronix - 5 years no issues also.
Rick Katigbak
Gretchen - 1972 3.6 ST-Replica
No Name - 1966 911 - 2.7S powered
Old 08-22-2007, 06:57 PM
AutoBahned
RWebb's Avatar
they are the std. thing to use when you get tired of cleaning the points with a business card every month...
yes, they make setting the dwell something you do every 5 years not every 5 months -- in that sense it is easier -- or have a shop set it & ferget it
Old 08-22-2007, 08:28 PM
So, how do you change it? What parts to you need?
1970 911 T
2004 Carrera 4S
Old 08-27-2007, 10:57 AM
Deschodt's Avatar
Don't like it
I bought a pertronix unit and it never worked. Might have been DOA but I sure paid attention to the installation instructions and did not fry it myself. So that is my data point. I was so annyed I did not return it but it's somewhere in my garage, where I threw it...
I don't understand what the big deal is with replacing points now and then. Some posts make it sounds like it's a weekly thing ;-) I've had a bunch of old cars using points and never knew the points were there. I adjust them when I remeber they exist, which is rarely, and the car(s) run fine ! It's not that hard, takes 5 minutes... And you do know when it's the points that give you trouble, good luck figuring it out with the pertronix since you cannot see anything obvious.
Old 08-27-2007, 11:04 AM
No Band
futuresoptions's Avatar
Just purchased and installed a Petronix ignitor on my 77' 911S w/2.7 engine.
Had one on my 73 914 1.8 for 7 years without a glitch... friend of mine has the car now and it still starts on the first crank.... I say buy it install it correctly and forget about it for good..... do purchase a spare to keep in the glove box just as you would a set of points.... but chances are you will never use it.......
"HEY A$$MAN!!!"
Old 08-27-2007, 11:14 AM
I assume you mean you've experienced a failure rate of less than 2%, yes?
Old 08-27-2007, 02:48 PM
47silver's Avatar
pertronix
one in our 2.7l for over 3 years and no problems, seems to start easier in the wet,,,but maybe not....
1975 911S Targa
Silver Anniversary Edition
Old 08-27-2007, 07:36 PM
I've had a pertronix in my 74S for about three years now with zero problems. I used to have to keep after the points, no more. there isn't anymore power, just alot less hassle.
Old 08-27-2007, 07:58 PM
