haycait911's Avatar
rebuild carrera tensioners?
I can compress the tensioner on the left side with my finger. the right side I cannot budge by hand.
which is the normal situation?
first, has the left tensioner failed?
I was getting intermittent LH noise, emanating from the chain housing, especiallly when hot.
has anyone rebuilt these things? and does pp have the kit, I can't find it on their site.
Old 06-09-2007, 09:04 PM
They don't last for ever, and some of the original upgrades fitted in the 80's have to be getting pretty old now...
The ones in my '78 930 motor were replaced "while we were in there" @ 90,000 (spun #6 bigend).
They had looked fine when the PO treated it to a pro top-end rebuild @ 65,000, and were re-fitted then.
Only the left hand one didn't look usable this time around, but we figured hey, they've probably been in there 20+ years, replace them both.
'77 S with '78 930 power and a few other things.
Old 06-10-2007, 04:12 AM
I'd replace both with OEMs (either pressure or non pressure fed).
Just too big a risk here not to do both as a failure could kill engine quick
1980 G-red 911 SC Targa
Old 06-10-2007, 04:41 AM
Have you gotten any response back re. anyone trying rebuilding the tensioners-- versus buying new ones?
Old 06-10-2007, 05:30 PM
haycait911's Avatar
haven't heard back from anyone who's actually rebuilt them, or where to get kits. that would still be my first option. I need to get this engine running properly before I can properly assess it. I don't want to spend more than necessary to do that. anyone?
Old 06-10-2007, 06:46 PM
I don't have one in front of me but I'd try to take the bad one apart and see what has failed. The easiest replacement would probably be to buy a used one from a dismantler like Partsheaven in Hayward CA.
I've never heard of a rebuild kit for these.
-Andy
Old 06-10-2007, 06:51 PM
haycait911's Avatar
can anyone tell me if I should be able to compress the tensioner with a finger. one side is rock solid, the other I can easily compress. which is correct? tensioners are still in place in the car. Don.
Old 06-10-2007, 07:19 PM
3.4 Bigger is better
88-diamondblue's Avatar
On mine I had to use a vice to compress the tensioners. Even in the vice it took a lot of force to compress them. My guess is the one that you can do by hand is toast. Replace it!
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 06-10-2007, 07:52 PM
You should have to use a vice to VERRRRY SLOOOOOWLY compress the the tensioners (to avoid damage) so they can bleed off the oil in the damper chamber. If you can compress with your fingers you may have a broken spring as well as shot seals. I have rebuilt several sets of tensioners as per the instructions in the factory manual. I have never had a failure since rebuilding BUT I have always fitted them with the little safety collars to prevent total collapse.
They are not hard to rebuild and the bleeding technique is straightforward. The oil seems to act primarily as a damper.
I think I have always gotten the kits from Stoddard and they were pretty cheap: like $20 each.
Good luck, Scott
73S sunroof coupe 68k second owner
73E driver/project
Old 06-10-2007, 09:14 PM
haycait911's Avatar
Scott, are you talking about the standard or oil-fed tensioners?
Old 06-10-2007, 09:22 PM
haycait911:
Sorry I was not more clear. I am talking about the standard tensioners used up until the oil fed Carrera tensioners were fitted in 1984.
Scott
73E driver/project
Old 06-10-2007, 09:42 PM
IMHO - I suggest putting in oil feds with Jerry Woods travel plugs. As mentioned when the oil feds are bled they are hard to compress and do it very slowly or you can break them. You can't even move them by hand. You will see oil slowly coming out of the weep slot at the top.... there should be threads out there on all of this.
Sold: 1989 3.2 coupe, 112k miles
Old 06-12-2007, 05:40 AM
Rebuilding Early Chain Tensioners
I have rebuilt these things successfully, and here are some tips for everyone's benefit:
1) Good tensioners are rock solid, and can not be compressed by hand; not even with a good pair of vice grips. If they can, the internal ball check valve is bad. If they can be compressed slightly with little resistance then get solid, they have air in them, and you need to bleed them.
2) Bleeding a rebuilt tensioner is tough, and requires 3 hands to do it easily; follow the procedure in the Haynes manual and you will see why. I found the only way to get every bit of the air out is to perform the bleeding proceedure with the tensioner submerged in a can of oil. Quite difficult and messy, but this was the only way I could get them to feel rock solid after I pulled the installation pin. Otherwise, they were spongy in the first 1mm or so of travel, after installation, (indicating there was still air in them).
Hope this helps.
69BahamaYellow
Old 08-23-2007, 01:29 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
Any chance you have a few pictures of the process?
I find the Haynes manual lacks in a lot of areas, especially pictures.
Thanks,
Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 08-23-2007, 07:26 PM
I rebuilt mine and they were rock solid when I installed them. They both failed shortly after, not sure why. Luckily I had safety collars. The rebuild process was pretty finicky. I don't think I'd do it again.
Joe
Old 08-23-2007, 08:43 PM
Chain Tensioner Rebuild
Here is a picture of a tool I fabricated to assist in the re-assembly process. This tool allows me to assemble everything while the tensioner is submerged in a can of oil and compress the piston rod using a small wire to open the ball bleeder valve (through the hole in the piston rod). I think the key is to never compress the piston rod into the tensioner unless you are relieving the pressure through the bleeder ball valve. I see lots of posts where C-clamps or vice grips have been used to compress these things for installation. I suspect this damages the bleeder ball valve and eventually causes them to fail. I would like to know if Targa T used the vice grip method to install his tensioners, which later failed. I'm not saying this is the only reason these things fail; obviously, the factory saw fit to update them to the pressure fed types for good reason. I can tell you that mine have ran for about 60K miles since rebuild with no signs of problems, but I also run the disks that Targa T mentions that prevent a total collapse if the tensioners fail.
69BahamaYellow
Old 08-29-2007, 03:39 PM
good points.. I compressed mine using very large channel locks and pressed slowly...
where is the picture? I like the idea of the wire to open the check valve...
Old 08-29-2007, 03:45 PM
Sorry the picture didn't come across the first time. The screw on top presses the top nail into the piston rod through the top of the tensioner. The nail on the side holds the top of the tensioner just above the tensioner housing so you can insert a wire into the small hole in the top of the piston rod. This will hold the bleeder ball valve open while the piston rod is pressed to the bottom of the tensioner. Then remove the wire and press down the top of the tensioner. No damage and no air trapped in them.
69BahamaYellow
Last edited by 69BahamaYellow; 08-29-2007 at 07:48 PM.. Reason: Instructions for use
Old 08-29-2007, 07:38 PM
