My '89 alarm is set & turned off by the ignition/door key. Does that mean that if I locjk the door with the key, wait a while, and then try to start the car, it won't start?
Cory -
As you probably saw in the post the fix worked perfectly first time on my '86. If you like I'll take a pic tonight in order to confirm the connections involved. Other than that I'm sure some EEs are out there to assist. Cheers, Pete |
Does anyone know the years that the alarm codes/modules changed?
It seems that this method will work for SC's and Carrera's - but the module was different. I would think the 84 would be different with the introduction of the DME. I have mine rigged right now but would like to remove all together... |
a new Porsche is supposed to be a pleasant experience. if i had your car, i think i'd be trying to get my money back. jmho
Cory -
I feel your pain. Best of luck and here is a quick picture. At top right the Blue & Blue/Red are capped together and black wire is connected to the fuse block (blue wire) http://forums.pelicanparts.com/uploa...1306901555.jpg |
| All times are GMT -8. The time now is 09:59 AM. |
