Send a message via AIM to hahnmgh63
Windshield seal 964 or 911?
Can I replace my windshield seal in a older 911 with the trimless seal of the 964? Or is there a problem in not installing the trim? Thanks, MGH
Old 08-10-2007, 05:10 PM
sudo apt-get purge 930
equality72521's Avatar
I'm not positive, but I think you have to use 964 glass as well. That was what I was told.
--clutch-monkey
Old 08-10-2007, 05:17 PM
Bump
Bump anyone know for sure?
Old 08-11-2007, 06:16 AM
PRO Motorsports
Tyson Schmidt's Avatar
You definitely need the larger 964 windshield for it to work.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 08-11-2007, 09:44 AM
964 Windshield
Does the 964 windshield fit the older 911's if you use the 964 windshield seal?
Old 08-11-2007, 10:42 AM
I'm surprised that ( by now) the recent and longish thread about this whole mess didn't yet show up. Claims and counter claims of working and not working.etc....also..that a 993 window with seal would work but a 964 would not, etc. etcc.
Do a search on the usual key words and be sure to include "Doc" ( Air-Cooled Classics fame)....as he was part of this thread. I'm not in a position to find it at the moment... anyone ??
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-11-2007, 01:52 PM
Thanks all, I did find a thread in the archives which is not definitive on a answer. Porsche did make a weather strip at one time without the trim but it is NLA. I guess for now I will stick with my old windshield. Anyone out there have a later carrera windshield with the internal antenna they want to sell? Thanks, MGH
Old 08-11-2007, 02:05 PM
Grappler
Rodsrsr's Avatar
I think it may be a case by case issue, as there may be some slight variation between cars.I installed a 911 windshield in my 76 coupe using the 964 trim, and its been that way for about 2 years now with no issues. There is some slight flex if you push on the windshield, and it overall just doesn't feel quite as tight as I think it should. I've had the car to at 140+ but I still think I may change it in the future.
Old 08-11-2007, 04:31 PM
I was told this week that the sc / 3.2 window frame is identical to the 964.
That would mean that you can use either windshield provided you use the corresponding seal for that shield.
I am after this because I consider replacing the 964 window that is originally installed in my '89 3.2 (!) with the older type which is considerably cheaper.
Better a good one for a lot of bucks, than a bad one for little
Old 08-28-2007, 01:17 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
if you dont like the trim on the early one, just remove it. It does NOT help hold the windshield in.
Old 08-28-2007, 06:23 PM
Air Medal or two
afterburn 549's Avatar
OK BLAH BLAH BLAH I have a older (1975) with stock windshild and a stock gaskit ,no trim. Also the rear is the same except for a lt wt plexy unit , Been to a 140 mph....nervous yes, did it come out ??? no!
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 08-28-2007, 07:07 PM
