rpollock's Avatar
Is this Starter Ring Gear Still OK?
I am having an issue with the starter grinding and not engaging. It is the OEM starter, on an 86 Carrera w/ a 3.6 Conversion. Worked fine until just recently and seems to be getting worse.
Suspected the ring gear, but it still looks acceptable to my untrained eye, could use opinions here.
Starter has been out and appears in working order, didn't get a picture of the drive gear on the starter, but it didn't have much wear.
Also suspect a weak battery not putting out full amps. What would people suggest as the min CCA for a 3.6 vram? Keep in mind this is a race car, so not too keen on laying in the 65 lb OEM monster.
1986 911 Coupe - Now 3.6!
1985 911 Coupe - The start of the addiction - Sold
Old 08-22-2007, 09:54 PM
Navin Johnson
TimT's Avatar
Looks fine
'69 911 GT-5
'75 914 GT-3
and others
Old 08-22-2007, 10:06 PM
I assume you rotated the engine and confirmed the other ring gear teeth are intact?
If so, I'd remove the starter and inspect the solenoid and pinion gear linkage. If worn or bent, the gear may not have the same extension as usual.
Sherwood
Old 08-22-2007, 11:37 PM
Ken911's Avatar
if you look closely at the pictures you can see a LOT of ground up aluminum filings, looks like maybe the starter shaft might be bent or something like that. not actually a ring or starter gear problem.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 08-23-2007, 04:54 AM
rpollock's Avatar
The engine was rotated at the time and the rest of the ring gear looks the same as above. We had the starter apart and the shaft looks fine. I think I will have the starter bench checked next and have the battery load tested.
Old 08-23-2007, 05:50 AM
the engine tends to stop in one of three places, so there would be a wear area every third of the way around the ring gear. the teeth get thinner and there is a noticeable burr on the tips.
206 637 4071
Old 08-23-2007, 08:38 AM
Ken911's Avatar
a second look at the pic make me think you cleaned it with a flapper whell and the particles are grit from that am I correct?
2019 Silverado 6.2L
Old 08-23-2007, 10:07 AM
rpollock's Avatar
Ken911, we didn't clean it. The camera flash makes it look very bright. I think what you are seeing is an oily mung/ dirt reflecting to the camera. We didn't find any shavings.
Old 08-23-2007, 10:43 AM
post a pic of the left side of the teeth. you haven't really shown the side that gets worn very well.
206 637 4071
Old 08-23-2007, 10:47 AM
rpollock's Avatar
John, these are the only pics we took. I'll take more pics of the ring gear and also the starter and post them once we have it apart again.
Old 08-23-2007, 11:03 AM
Those metal specs are normal. It is possible that the throwout solenoid is going bad so it only raises the starter gear a bit of the way up. Start by giving the battery a good deep long charging. Then if that doesn't work, find someone who rebuilds bosch starters and have him rebuild it. The ring gear seems fine unless there is a spot on it that is terrible.
Old 08-23-2007, 12:44 PM
rpollock's Avatar
Looks like EarlyPorsche nailed it. Had the starter rebuilt. All is well. Thanks for all the insights and tips above.
Old 08-29-2007, 04:24 PM
