keeping CV bolts tight..............help
Twice this week I've dropped a halfshaft on two different cars. Fortunately,
I was coasting to a stop when they dropped. I couldn't imagine what it might be like at freeway speeds. I used locktite ( red) even. Any trick ideas.
76 911S
81 911 SC
66 912 V8
66 912
71 914 project car
79 930 project car
H2 triple drag bike fast-by-gast
Old 08-28-2007, 04:01 PM
Driver8's Avatar
Jess what year and make are the cars? Did you install them dry? Did you torque them to spec?
Old 08-28-2007, 04:03 PM
My 76 911s and my bastardized 912 V8. I tightened them as tight as I
could by hand.
Old 08-28-2007, 04:05 PM
Driver8's Avatar
Jess there is a specific torque value for those bolts. I am on the road and don't have access to my manuals I'm sure some one will chime in with the correct torque value. I would also recommend installing new bolts, with no lub or loc-tite, that should fix the problem.
Old 08-28-2007, 04:14 PM
Shaun @ Tru6's Avatar
do you have the half moon plates and schnoor washers?
Tru6 Restoration & Design
Old 08-28-2007, 04:18 PM
Grady Clay's Avatar
While very long, this is the definitive thread on this subject.
Reconstructing Constant Velocity (CV) Joints
It is worth reading completely.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Jeff Hail's Avatar
The 914 Underdogs got part of the problem "wired" as far as the bolts are concerned. Cost is cheap and the fix is race proven .
http://www.914world.com/bbs2/index.php?showtopic=54963
Jeff Hail
"All men dream: but not equally. Those who dream by night in the dusty recesses of their minds, wake in the day to find that it is vanity; but the dreamers of the day are dangerous men, for they act their dream with open eyes, to make it possible"
Old 08-28-2007, 05:04 PM
North Coast Cab's Avatar
I've had some of those issues myself in the past. There is lots of good reading, but here are a few of my basic tips.
1) Inspect the flanges. If a few backed out it is very possible the holes were deforemed and therefore will not stay tight again
2) Clean, clean, clean. Use a q-tip to clean all the threds and holde where the bolt goes of grease prior to torquing.
3) Use some locktite
4) Wire tying will keep them from falling out, but will not keep them tight.
5) Check them often
1985.5 944 GTS
Old 08-29-2007, 04:17 AM
abit off center
cgarr's Avatar
+1 The only way to go, you got it!!
______________________
Craig
G2Performance
Old 08-29-2007, 04:35 AM
iamchappy's Avatar
Safety wires when installed correctly will not loosen, they tighten against each other as they try to loosen...
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 08-29-2007, 05:08 AM
my setup is for a stock 89 - I cleaned the threads and surfaces very well, put never seize on the threads, torqued to spec. then put marks using a paint pen across the bolt head down to the "washer". Then you can inspect to see if there is any movement. 10k miles and 5 track days... so far so good.
Old 08-29-2007, 06:10 AM
Slumlord
Porsche_monkey's Avatar
Did you use a loctite cleaner first? Loctite is useless if the bolt or the hole is greasy.
You should not have to use red loctite, blue should be fine.
Old 08-29-2007, 07:26 AM
Thanks for all the advice. I think I'll use safety wire
Old 08-29-2007, 08:59 AM
AutoBahned
RWebb's Avatar
safety wire is not needed if you install them correctly to begin with
there is also the possibility that the hole may make the internal wrenching feature (the allen key female part) less strong -- it is already troublesome in stock form
and ther is the hassle of drilling the frickin' bolts -- unless you find some A/N std. bolts with holes already there
All in all, I consider drilling the holes to be something done for cosmetic reasons or by those who don't understand how to install them correctly
Old 08-29-2007, 12:08 PM
Blk95993's Avatar
Had this happen twice. Good advice and thanks for posting. Feedback will help me as well post engine drop.
Porsche-Less at the moment....
Old 08-29-2007, 05:24 PM
