SC hesitates at 3-4000rpm
When I accelerate up to between 3000-4000 rpm and hold the rpm steady, the car lurches slightly like it's not getting fuel or spark. The fuel pump, accumulator and filter is 5 years and 10,000 miles old. I'm thinking about changing the filter. My thinking is that there is some dirt in the filter stopping a steady pressure flow of fuel to the CIS.
Any thoughts or additional suggestions before I order a filter from Pelican? On another related item, has anyone replaced the stock CD ignition unit with the MSD? If you did, what was the result? |
Trotskyite
I have the exact same problem, but only when the engine is hot. I thought fuel filter too, but wouldn't it hesitate at any RPM? It also has had some trouble starting when warm, but fires right up cold. Power seems to be a bit down overall too, but that could just be me.
Two things here, surging could be a lean condition. But start simple, how is your vacuum advance working? As far as the MSD goes, you're not going to notice much outside of the normal CDI, Bosch did a great job on it. That being said when mine went I replaced it with an MSD, only for cost reasons.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
I had a backfire a while back and blew the pop off right out of it's seal, epoxied it back in and thought I had it. Maybe there's a small crack or hose that's been damaged. Last edited by gregg911; 09-01-2007 at 05:03 PM.. Reason: I'm not in the typing pool |
Update...fixed
I checked the vacuum line to the distributor, it looked good, hose was good, connections tight. Took the cap off the distributor and moved the rotor to make sure that it would advance, it all looked good.
Then I checked the inside of the airbox and with a flashlight noticed a 1" crack at the back of the box. Used a 5 minute 2 part epoxy and sealed the crack, let it dry overnight and drove the car this morning. It runs great!! |
Somatic Negative Optimist
Alright, good fix.
Consider servicing the distributor anyway. I posted an easy way to clean and lube, enjoy. Distributor service (Clean and lube) real easy without removing the pinion gear!
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
as for the possible vacuum issue, how is your idle, high? If it's high maybe check the route first as high idle is one indicator.
Bjorn 1987 911 Carrera 2001 Volvo XC70 Last edited by Fronnzy; 09-03-2007 at 11:18 AM.. Reason: mistake |
