RSR Clone Tire Clearance Question
I will be running 245X16 front tires on my '73 RSR clone. It looks as if I will have interference with the dust boots on the front struts. Are any of you guys running tires this wide with dust boots on the struts?
I am thinking that the dust boots will have to go.
Old 06-30-2005, 07:21 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
I have 245/45/17s on a 9"rim on the front with about 1" clearance between the tire and strut cover. I think it all depends on the wheel/offset your running.
Marc
Old 06-30-2005, 07:25 PM
If 245's fit between the strut cover and the fender lip, I would expect that I could use the right size spacer to get the tire positioned correctly.
Old 06-30-2005, 07:45 PM
Administrator
Jack Olsen's Avatar
I'm running 255's, and Tyson has a plan to remove my coils (and substitute in torsion bars, and add effective spring rate with the JRZ's nitrogen pressure) so that I can run 275's in front.
But my car is kind of a one-off. Too many mods for a useful apples-to-apples comparison.
Old 06-30-2005, 09:25 PM
Crotchety Old Bastard
RarlyL8's Avatar
I'm running 255/35-18s on 9" rims with no problems. (930 fenders on a '78SC)
My old '73T had 255/40-15s on 9" rims. (weld-on flares) Also no issues.
Old 07-01-2005, 11:06 AM
Tom,
I hope you don't mind me digging up an old post. What did you end up doing to fit the 9x16 Fuchs with 245/45/16 tires up front? Did you end up removing the strut dust covers, use spacers, or what?
I'm thinking about using the same front wheel/tire setup on my widebody. Thanks for the help!
Old 02-01-2008, 10:16 AM
Kaefer
I am using 1/4" spacers and no dust covers on the struts.
Originally Posted by Kaefer View Post
Tom,
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Recreation in Process
Old 02-01-2008, 02:43 PM
AFCuk's Avatar
Originally Posted by tom1394racing View Post
Kaefer
Me too 245-45-16s but got the dust covers on still
83sc targa BBT
Old 02-01-2008, 04:05 PM
