fuchs weld repairs?
Ok I am not really looking for the typical response of "I wouldn't do it? But wondering why the fuchs wheel is amoung the strongest wheels ever made supplied from any automotive factory but they are considered junk if you tweak them or have any cracks in them. However the rest of the automotive world often repairs and welds them etc to bring them back to factory specs etc.. So my question is why more people are not welding the 9X16 fuchs which are most prone to cracking? Is the welding of a crack on a wheel causing extreme stress risers not seen on any other wheels in the world Please explain? I think that most the cracks that I have seen on the forum pics of fuchs could be easily repaired but really looking to see what everyones thoughts are on this. Now cracks are not always as small as they appear but once heat from the weld is applied you can follow the crack.. Just help me see this. make it simple for me please..
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Information Junky
The heat of welding will Soften the Aluminum near the weld.
Tho ' Welding (having a weld there) will certainly be better than having the crack (saw your post on the g b. site.. was going to ask for a pic.. maybe post a picture here when this site is back to 100%)
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
abit off center
Doesn't someone make these wider by welding two together?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Registered Cruiser
I'm with Craig on this one. Lindsey welds up entire wheel sets that have been used extensively on the track with enormous loads.
87' Carmine Red Carrera - Keeper 82' Silver SC - Sold 79' Gran Prix White SC - Sold 05' Black C2S - Daily driver I have never really completely understood anything. |
Large Registered Member
I may be wrong, but I thought the most stressed out area is the one that normally cracks... On the pedal near the lug nut... Lindsey welds where 2 wheel halves are put together, not on the high stress area that normally sees cracks...
Of course, now someone will post a picture of where the weld broke of on the wheel section...
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) Last edited by PatrickB; 09-02-2007 at 04:31 PM.. Reason: spelling |
Fuchs w h o r e
As island said, a forging gets its strength from being stamped at a specific temperature which allows the grains of the metal to stretch. When they cool, they have built in stress which makes them stronger. Think of the grain structure of a forging as like spaghetti, while a casting has the grain structure of oatmeal; very homogenous small grains.
When you heat the metal to weld it, this stressed grain structure relaxes and the grains coalesce to a smaller size, and a great deal of the inherent strength goes with it. ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
abit off center
Maybe you could have the wheel heat treated? Maybe these keep cracking in these areas because of the working stresses (work harden) and constant heat cycling from braking, don't know but these wheels are getting old.
Well for street driving I would think the cracks could be repaired without major issues. The crack in question is 1/2 inch long right buy the center cap.. it is a hairline crack and almost just looks like a small scratch and does not look to be completly through to the other side. I have seen this type of crack on a lot of fuchs. One thing to note is typically the weld area(HAZ) is harder then the base material.. Interesting. Do you know what lindsey uses for filler wire in their welds? any one? 4043 or 5056?
Information Junky
The HAZ is softer.
My theory is, that type of "center cap" crack gets started from abuse to the center cap mounting surface. That is, a new wheel has a nice smooth surface, where old wheels are often gouged. That area (as new) should NOT be a stress riser of any sort. If it's cracking there, it is most likely something else causing the high stress in that area. (tire machine?) SO, if you know anyone who can lay a decent bead I say go for it. Clean it up, and keep an eye on it. Let us know how it goes.
What about the guys who everyone sends their rims to to be refinished, what do they have to say on the subject??
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
They fix em!
Ben, how hot will you preheat the wheel and how will you control the cool down? This, to me seems like 80% of the problem with the rest being how to exactly match the graining of the original wheel (can't).
Are Fuchs heat treated?
'83 SC |
Information Junky
Milt, I think he's okay to weld there. As far as I can see that center cap area shouldn't be highly stressed. Well, except for those tire bead-breaking machines that grab the wheel by it's center cap mount with a big wedging cunk of steel, whilst a enough force to pull the tire off the bead is quickly applied.
This is way more important with cast items mostly with cast iron.. I have welded many many rims(wheels) with 100% success. so this would be the first "structural" fuch repair
