85 Carrera base idle Lambda and AFR values
Just a sanity check:
When setting base idle AFR on a Carrera with an LM-1, what should the Lambda and AFR readings be? Everyone talks about CO%. Thanks Dave |
With the O2 sensor disconnected, have the idle afr between 14.2-14.7:1
Thanks Steve- Back to the drawing board based on my other thread.
Dave |
| All times are GMT -8. The time now is 11:36 PM. |
