ML-350 brake job
Yes > fully realize what the blink am I posting a question wrt Benz 06 ML-350 front brake job [rotors and pads] on the 911 site.
Searched around all over on the Benz site - and folks there [Benz-world] act like divulging torque specs is giving up the family jewels.. really - like I know but I'm not telling you.... Been a Pelican for lotta years > and I find Pelicans pride themselves [justifiably in their in-depth knowledge of all things Porsche > and other cars too] ergo anyone with torque specs for ML-350 front and rear rotors ?? one post noted blue locktite?? anything unusual wrt the ML-350 brake system ? thanks kgl
Kim Langley 2012 Carrera / 991.1 80 911SC 97 C230 73 BMW 2002Tii |
one of gods prototypes
Fyi if it has the sbc brake system you can lose a finger....not sure if out came in the ml's....the sbc pump is clearly marked and looks like an abs block..if it does you need to deactivate it before you touch the pads..
Iirc the calipers get around 60 ft lbs....the rotors just good n tight, the bolts that secure them to the hub don't do much, the lug bolts clamp tight when you put the wheels on....
Brought to you by Carl's Jr. |
