-   -   Idle change warm to hot at stop, which device am I looking for? 82sc (http://forums.pelicanparts.com/porsche-911-technical-forum/365319-idle-change-warm-hot-stop-device-am-i-looking-82sc.html)
dbrisson 09-03-2007 06:01 PM
WHile its not a big problem I just want to know if its normal or is something out. I set the idle mix and have a solid idle (maybe a tad low but strong and solid) when cold and warm.
After long drives or when its excessively hot (meaning normally the temp gauge is way below the middle but during a 95+ day it will creep up to the middle or so) I notice the idle change at stop lights or when sitting still.
Its not a creep and hold like a leak but a ramp up a few rpms then kick back down as if something is opening and then closing.
What components should I check or replace or is this just a normal device richening or leaning the idle at the stop?
Thanks for any help
D.Brisson
82sc GHL single in out, cat bypass. Otherwise stock with new filter, plugs rotor and cap.
Sold my MG so now its into really tinkering with this one....
Gogar 09-03-2007 06:02 PM
What year of car?
SCWDP911 09-03-2007 06:23 PM
Originally Posted by Gogar (Post 3459984)
What year of car?
"82sc GHL single in out, cat bypass. Otherwise stock with new filter, plugs rotor and cap."
:D
dbrisson 09-03-2007 06:49 PM
The lower part wasnt there during the first reply added during edit, although the 82 was in the title.:):) Any way where should I start? I am guessing the "check the pressures and cis overview. ...
Paulporsche 09-04-2007 06:23 AM
Your warm control pressure might be a little low, resulting in a too rich warm condition. It's also possible your mixture may be simply set a little rich.
