Hand Throttle Question
The hand throttle in my 69 911 seems to have become disconnected. It now has no effect when I move the lever back and forth. This forces me to hold my foot on the throttle until the engine warms up.
Is there an easy fix for this? I can see very little through the small hole in the left side of the tunnel provided to adjust the hand throttle. Do I need to remove the emergency brake base to fix it?
Old 08-31-2007, 04:25 PM
Try this thread, it's related to your question and may hold the answer.
1973 MFI hand throttle
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 08-31-2007, 06:39 PM
The plastic connector piece has probably disintegrated.
Someone needs to produce an unbreakable aluminum replacement.
Jim
Old 08-31-2007, 07:08 PM
easy thing to do—I did mine two days ago after having had the part for almost a year. follow the thread posted and it's a snap. It's good to have the cruise control back.
Don
_________
72 911T Sepia 2.4
08 Audi A6 quattro 3.2
03 Toyota Tundra
Old 09-01-2007, 08:52 AM
Thanks for the pointers.
I removed the bolts from the handbrake assembly and was able to lift it enough to verify that the plastic piece is broken. However, I can't seem to lift it (or rotate it) far enough to get the C-clip to where I can take it off? Do I have to disconnect the emergency brake cables to do this? Any tricks?
Old 09-04-2007, 11:48 AM
Zeke's Avatar
I'd say (if my memory serves) that the HB ass'y needs to come out. Why not, anyway? You can lift the lever and hold the cables under the car so that reattaching is easier. Again, I don't remember exactly how I did this, but most of us that had an early car had a broken hand throttle at one time or another.
Old 09-04-2007, 11:58 AM
my cables are tight and I could get it rotated enough to get to it. my plastic piece was broken off so I had to work to fish it out. I found it so much easier to work on this with the drivers seat removed. someone else suggested it and they were correct. take you time, you should be able to do it.
Don
_________
72 911T Sepia 2.4
03 Toyota Tundra
Old 09-04-2007, 07:21 PM
