Should I install the bump steer kit?
I am about to have the turbo tie rod kit installed. Should I have the bump steer kit installed at the same time?
Ride height on my car is 25.5 front, 25 rear. |
I doubt you need it with that ride hight, but difficult to say for sure.
Look at your tie-rod angles.
If they are not level at your current ride height and angle upward from the steering rack to the steering arms, install the rack spacer kit. |
If you need it, do it at the same time - you'll be in there anyway.
I put one onto my SC along with the turbo rods and it made an amazing difference in the car. Much nicer to drive now. |
If you need it, you can feel it.
I tell most of my customers with your ride height to install BSK. Of course, most of my customers are running an 1/8th inch toe out in front, so it stand to reason that they'll have more need for it.
Jason Porter,
Can you tell me why toe out? |
For customers going higher speeds, alignment corrections are required. |
Jason, thanks.
Went with the BSK and the complete turbo tie rods on my '88
two years ago...wow, what a difference :D....couldnt figure out how the PO could drive it the old way....but then he was a cheapskate on maintenance....:( Had to laugh...he said he had bought an airplane...wait untl he pays for upkeep on it...yikes! |
| All times are GMT -8. The time now is 09:57 AM. |
