CMDR Perry's Avatar
Porsche Crest 911SC engine bay 1 day makeover
Before SS headers with heat
After SS headers, no heat
1986 Mazda Rx-Vetten LS1 swap street / track car
2007 MX-5 Roadster, Cinnamon, MC STR champion (sold)
2013 Scion FR-S, MC STX champion (sold)
2002 Roush Stage 2 (traded)
1979 GP White 911SC coupe, aka "Bruce
Old 09-04-2007, 07:47 PM
Danny_Ocean's Avatar
Very nice. How 'bout some under-pics? I'm getting ready to do the same thing, but I think I'll keep my heat.
Old 09-04-2007, 07:52 PM
Detached Member
Hugh R's Avatar
No heat in MN, Ok
Hugh
Old 09-04-2007, 09:15 PM
Band.
Lookin good! If your car feels faster, it's not the SSIs and the weight. It's the Carbon Fiber Airbox cover.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 09-04-2007, 09:59 PM
Mitch Leland's Avatar
Comander Perry,
What material did you use on your fan and fan housing? Did the Megnecor wires work out well for ya?
Thanks,
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 09-04-2007, 10:55 PM
CMDR Perry's Avatar
911SC Engine bay
To all; the fan and housing are beadblasted (natural) and clear-coated. The plug wires are from our host, fit perfectly and work great. Believe it or not the air box cover actually does improve CIS throttle response and non-Porsche tech people love it. This is a summer toy and global warming is a reality in the great white north so I don't need heat. I will try and post some floor angle views later this week. Thanks for the compliments.
Old 09-05-2007, 04:08 AM
Shaun @ Tru6's Avatar
Is that a Fram oil filter?
Tru6 Restoration & Design
Old 09-05-2007, 04:11 AM
CMDR Perry's Avatar
911SC engine bay
No not a Fram. It is Purolator oil filter given to me by a co-worker with 3 Porsches (911, 914-6 and 928).
Old 09-05-2007, 03:10 PM
Won Won is offline
Won's Avatar
Garden hose for breather lines?
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 09-06-2007, 03:44 AM
Now give it back and get a Mahle or Porsche filter instead! Nice job on the engine bay "cleanup"! I found that "Goo Gone" (i.e. specifically, not some other like Goof Off), along with some heat works fairly well in removing that dried glue from the engine sound pad (it's still a real PITA though).
Old 09-06-2007, 04:13 AM
CMDR Perry's Avatar
911 SC posting mistake
Won tough crowd, no it is not garden hose. It is reinforced PVC chemical hose and holds up well for hot oil vapors. Go to any pro race and you will see it being used for vent lines on oil tanks, etc. It should not be used for a suction line on a pump. KC I do have a correct black Mahle oil filter in the garage for my next oil change so you can rest easy. Anyway thanks for the glue removal tip, I need to add it to my winter project list.
Old 09-06-2007, 03:29 PM
Evil Genius
Rusty Heap's Avatar
2nd on the crappy glue look showing on the bare fire wall, tsk tsk..........I put in a silver quilted sound pad and it really dresses up the engine compartment. Much better than the ratty black ones.
Life is a big ocean to swim in.
Wag more, bark less.
Old 09-06-2007, 03:43 PM
Dave,
I'm thinking of doing the same thing, can you post a pix or two to show your firewall insulation? I was told today that there's two 6 mm holes on the underside of the rear shelf that you could use to help support the insulation on the horizontal part of the firewall. This is the area where the insulation falls down. You could either use a large fender washer or put an aluminum or S.S. strip across the bottom of the shelf to support the insulation.
Mitch Leland
Old 09-06-2007, 03:58 PM
Won Won is offline
Won's Avatar
Sorry, I was just being a smart ass, I should have included one of these guys -> . I actually went through almost exactly the same clean up process with my 83 too; removed the insulation, pulled out blower motor and cruise control unit, JB Welded in 2 1.5" PVC elbows for "backdated" heat.
I might cut up my airbox cover too.
83 911SC Targa
Old 09-06-2007, 05:44 PM
Won,
I've read that opening up the air box doesn't create any go power, just good noises. Here's a thread on mods including air boxes.
'88 911 3.2 Performance upgrades?
Mitch Leland
Old 09-06-2007, 06:32 PM
Won,
Mitch Leland
Better in Person
juanbenae's Avatar
do a search for "backdated heat" and you can restore the heat. the fan moves air through the exchangers with some older type add ons. you can maintain your engine bay as it is now with this mod. try parts heaven, i think they are producing the stuff needed for this "upgrade".
T$
Old 09-06-2007, 06:50 PM
Better in Person
juanbenae's Avatar
oh yeah, did someone say clean engine bay? post sound pad removal...
T$
Old 09-06-2007, 06:54 PM
CMDR Perry's Avatar
911SC e-bay
Very sanitary engine bay Tony. But guys you are not listening. I said SS headers! Heat is no longer an option.
Old 09-06-2007, 07:03 PM
Toby, Very nice...
What did you use on the trailing arms and underside to get it so clean? Does anybody know what the difference in noise levels are with or without the sound pad insulation?
Mitch Leland
Old 09-06-2007, 07:04 PM
