Torque value for alternator ground wire?
Does anyone know the torque value for the nut on the top of the engine that fastens the brown ground wire to the alternator? It's a 13mm.
I took the nut off to clean the ground contacts but Bentley doesn't mention the torque for it (or I can't find it).
Thank you.
-Terry
Old 09-08-2007, 03:33 PM
304065's Avatar
Same as any other case parting line nut, 25 NM (18.4 ft-lb). That is one of the nuts that holds the engine together so make sure you don't relax the torque on any adjacent nut while it is loose.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-08-2007, 04:02 PM
Got it. Thank you John.
-Terry
Old 09-08-2007, 06:19 PM
