LinkBack | Thread Tools | Rate Thread |
Uhhh...Take a look down the throats of the right side webers please
Cylinder #4 carb throat:
Next throat behind that: And finally, the normal looking 3rd throat in the back: ![]() Am I looking at 2 melted auxiliary venturi tubes? The K&N filter has a melted spot on it corresponding to these locations, so it looks at there was some kind of firey spit-up in the past. How difficult to rectify this situation? Do you recommend fully rebuilding the carbs while I'm at it? Any advice is appreciated.
Sepia brown 1971 911T. |
is that some kind of melted rubber in the first to pics or is that melted metal? I would use about 2 cans carb cleaner and clean the **** out of those
"Work harder........... Millions on welfare depend on you" " If you aint cheaten you aint tryin" |
I'm so dumb...I just had an epiphany...the melted stuff is *probably* melted glob from the rubber filter element lining...
I mean,. it would have to get awfully hot to melt those tubes themselves...I guess it's time to yank the carbs from the car, and go through them. I'll be ordering a carb rebuild kit tommorrow. And a new K&N filter or two.
the tubes melt just fine.
Yep, the vents are melted.
DOUG '76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's. '85 911 Carrera, stock, just painted, Orient Red |
Time for new ones and furthermore, dealihng with what caused them to melt in the first place,.....
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
