myrddin's Avatar
Door Seal Question
When installing the door seals do the holes go on the outside where you can see them or inside next to body? Also I notice there is a hard rubber corner in the seal but its on the same exact spot on both seals (cab door seals) what is it there for?
thnx
looking...
Old 09-12-2007, 07:27 AM
myrddin,
I have only replaced my door seals once with the new kind (like yours) and as I recall they are the same seal for both sides thus on one side the holes will face out, and on the other side the holes will face in. As far as the hard rubber corner, I believe it goes at the top of the door jamb, at the corner of the lock post/quarter window.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 09-13-2007, 05:52 AM
Evolved
Mo_Gearhead's Avatar
Well, I am certain the OEM seals I got were 'mirror images' ...not alike.
The holes go out ... so the seal can breathe/compress/expand.
Don't fear the reaper.
Old 09-13-2007, 06:31 AM
myrddin's Avatar
thnx guys... I will leave the holes out for now and see what I find out.... Please keep the comments coming..
looking...
Old 09-13-2007, 06:52 AM
joefrantz's Avatar
I don't think there should be a corner on cab seals, since there is no window frame. See the PET illustration at this link.
http://www.pelicanparts.com/cgi-bin/PartsLookup/search.cgi?command=show_page&Catalog_Name=911_USA_78_83_KATALOG&Illustration=804-00&Line_Item=23
My only experience is with coupe seals. For those, the seal shape is squared off and firm on one side, rounded and squishy with holes on the other. The square firm side is inserted (glued) into the channel around the door. The squishy side with holes faces out -- on both doors.
Hope this helps.
Joe
Joe Frantz
73 911 T
Old 09-13-2007, 06:54 AM
myrddin's Avatar
well its not a corner per say but it ends up in one bottom corner or the other... its solid where the rest is hollow I just thought it to be odd is oll. I have the holes out now and will see what happens.....
looking...
Old 09-13-2007, 07:52 AM
deshetlr's Avatar
There were 2 hard corners on my coupe seal. Upper rear and lower front. Holes are up.
Scott
'86 911 Carrera Coupe, PCA, PBC
Old 09-13-2007, 11:44 AM
myrddin's Avatar
I have a cab.... thanks for your info.. I now have the holes up.....
looking...
Old 09-13-2007, 03:32 PM
