Need Weber pump valve & spring...source?
I recently noticed fuel leaking from the accelerator pump of my one of my supposedly "rebuilt" carbs.
Took apart the accelerator pump, and the pump valve and spring are missing! Took apart the accelerator pump on the other carb...same problem! The guys who rebuilt these must have lost them. www.youroil.net doesn't have these parts (they get their parts from PMO)...any other place that might have them? In any case, I need two of #24 (spring) and two of #25 (pump valve) in the following diagram. Here's a photo...the first two items on the left are what I need. ![]()
anyone?
(the shotguns)
Did you fax Richard at PMO?
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Call Richard at PMO. He can take care of what need for your Carburetors. 310-394-0088.
