FenderGuy's Avatar
How rare is this part to break?
On start up to go get emissions testing and shipping off parts...my car started differently, idiling up and down...opened the hood and look what I found
Called the mechanic and said he has never heard of nipple breaking off in the vacumm retard unit
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 09-28-2007, 08:41 AM
kqw kqw is offline
Someone in the past probably used the wrong tool to remove the distributor.....
The Fox
Carrera
Old 09-28-2007, 10:03 AM
FenderGuy's Avatar
Yikes
Don Jackson just called seems they buy parts from Pelican and they are out of this part....anyone have one ????
Frank
Old 09-28-2007, 11:11 AM
obsolete at the moment. that's a retard and you can live without it, but retarding the timing does help to lower HC emissions. without it attached to vacuum (vacuum at idle only), the idle will be higher because the timing is now more advanced at idle than when it was working. the total advance does not change though. so to live without it, turn down the idle speed to 950-1000 and reset the CO. to pass emissions if it isn't functioning and emissions are still a tad high, retard the timing somewhat to lower the HC and reset it after you pass. for a visual inspection, maybe glue a hose in there so it looks like it's attached.
206 637 4071
Old 09-28-2007, 12:00 PM
Friend of Warren
If you can't get the OEM part it should be fairly simple to epoxy in a vacuum nipple from an auto parts store.
Kurt V
Old 09-28-2007, 12:06 PM
Or silver solder a fitting on.
Brian
Old 09-28-2007, 12:07 PM
Don't do it!! You'll burn up the diaphragm.
Old 09-28-2007, 01:18 PM
#29 SCWDP (muhaahhh!!)
Gene Wilkes's Avatar
JB Weld!
IslandmanFL
SOLD...78 911SC (ROW) cabriolet/widebody
hear BEBE purr!!
92 325is
Now living in Sunny West Palm Beach FL!
Old 09-28-2007, 01:28 PM
FenderGuy's Avatar
John and others thank for the advice I'll just wait it out untill the part gets here...
How hard is this to change out? My mechanic said there is a spring in there that tends to fall out and they use a magent to catch it, it is pretty much straight foward change?
Frank
Old 09-29-2007, 08:25 AM
no spring in there. two outer screws and unhook the end of the inner arm from a dowel it slips over. probably will have to pull the distributor out, so be sure you are familiar with that procedure. get the rotor pointed to #1 notch on the distributor body and duplicate that on the reinstall. then there's usually an obvious clean area where the hold-down washer sat, so put it back in that position, then the timing is virtually the same, for those without a timing light. you can also scribe around the washer.
206 637 4071
Old 09-29-2007, 08:34 AM
chris57's Avatar
This just happened to a friends sc. Blocked off vacuum line and all is good now
1985 911 "turbo look"
2008 Foose F150 (free truck)
2002 Mercedes Benz S55
Old 09-29-2007, 09:39 AM
