JWest's Avatar
Arrow New Headlight Relay Kit available from Pelican
Following our highly successful line of electrical products for the 914, JWest Engineering has introduced the Headlight Relay Kit for the 1974 to 1989 911.
With the relay kit, the electrical current travels straight from the battery to the headlight circuit at the fuse box, greatly reducing the load on the headlight switch and the failure prone column switch.
In addition, more power is supplied to the headlights for maximum light output.
Our easy-to-install kit uses factory connections and mounting points. High quality screw-together terminals join the new and old wiring together. No crimping or drilling required to install.
Due to the size of the factory wiring from the fuse panel to the headlights, the bulbs should be limited to a maximum of 100 watts.
You can order through Pelican:
Part# JWST-911-HLPR --- $25
James
JWest Engineering
Old 09-12-2007, 11:56 AM
Bug Eating Member
frogger's Avatar
What about pre-1974?
Old 09-12-2007, 12:03 PM
shahram's Avatar
subd
Old 09-12-2007, 12:09 PM
JWest's Avatar
The wire lengths and terminals in this kit were made to fit perfectly into a '74 to '89 911. The early cars had a different fuse box location that changed in size over the years.
If there is enough interest I may create a long-hood version in the future, but for now the current version could be adapted. This would require finding an appropiate mounting position and possibly changing the power and ground wire lengths.
James
JWest Engineering
Old 09-12-2007, 12:10 PM
Less brakes, more gas!
euro911sc's Avatar
If it simply a matter of increasing the wire length to accommodate all model years you may consider it as your available market will expand for not a lot of additional cost. Though, perhaps it is not so simple.
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 09-12-2007, 12:23 PM
targa todd's Avatar
Question...
So I've heard of relay kits for the purpose of accomodating higher wattage bulbs...
Do I understand correctly that this kit will improve the light output of any setup, such as my existing H4? If so, for a great product.
'87 930 - 100% stock
'89 951 - 100% track
'08 Audi RS4 - daily
'85 911 Targa - sold
Old 09-12-2007, 12:37 PM
Wash. State
nesslar's Avatar
...with spiritual consolation to flat6turbo I should imagine....
Hey! I recently got my Pelican sticker!
Old 09-12-2007, 12:38 PM
JWest's Avatar
Best regards,
Michael
Thanks. It actually would make a messy install for one of the applications, and I don't want to compromise the quality of the product to accomodate more years. One product at a time...
James
JWest Engineering
JWest's Avatar
The 911 has a less robust design than most cars - not only running the circuit through a conventional headlight switch but also using very small contacts in the column switch to carry the headlight current. Saving this switch from imminent failure (even with stock bulb wattage) is the primary concern.
Because the relays cut out a portion of the circuit path that travels back to the dash, through multiple contacts, and back up to the fuse box, the voltage drop is less and the existing bulbs will likely produce more light output.
The current for higher wattage bulbs are easily carried by the new relays, but the headlight wires further downstream are smaller than 14 AWG. This limits how much load should be placed on the circuit. The factory connectors on the back of the headlight can also melt if exposed to too much heat from powerful bulbs. So the kit is limited to 100 watt bulbs due to the overall system design.
James
JWest Engineering
Old 09-12-2007, 12:51 PM
targa todd's Avatar
Ordered.
Old 09-12-2007, 12:55 PM
MIK911's Avatar
James said:
"Due to the size of the factory wiring from the fuse panel to the headlights, the bulbs should be limited to a maximum of 100 watts. "
So is the stock wiring adequate for 100W bulbs + relay?
thanks
Mike
'86 911 coupe
'85 BMW 535i
'11 Cayenne
Old 09-12-2007, 10:02 PM
JWest's Avatar
thanks
Yes, the stock wiring is fine for up to 100W bulbs once the relay kit has been added.
James
JWest Engineering
Old 09-13-2007, 09:31 AM
Model Citizen
herr_oberst's Avatar
Sub'd. My next upgrade, I think.
I hate to display my ignorance, but will the dash lights be brighter?
Old 09-13-2007, 10:14 AM
Does this kit offer any advantage over the Sucro relay kit or is this just another option to consider?
Sherwood
Old 09-13-2007, 10:19 AM
ianc's Avatar
I'm curious about this bit. The factory power cables run from the switch to the fusebox for distribution. When you install these relays, you need to take that existing cabling and use it to energize the relays when powering the beams. If you don't crimp or solder, how do you tie those existing cables into your kit's integrated wiring?
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 09-13-2007, 11:19 AM
JWest's Avatar
No effect on dash lights.
James
JWest Engineering
Old 09-13-2007, 11:27 AM
JWest's Avatar
Sherwood
I'm not too familiar with the Sucro (never had one in my hand), but as far as I know they accomplish the same task. I don't know how that kit is terminated or mounted to compare.
The JWest kit is available for immediate ordering from Pelican.
James
JWest Engineering
Old 09-13-2007, 11:29 AM
JWest's Avatar
ianc
Good question - I'll explain a bit further. On the connections to the factory feed wires we have a special butt connector (posi-lock) that uses a compression fitting on the end of the wire.
James
JWest Engineering
Old 09-13-2007, 11:34 AM
Question
I was going to install the JWest 911 Headlight Relay Kit that I picked up from Pelican, but as you can see in the picture there are two differences between my vehicle and the instructions that came with the kit:
1. my wires on terminals 6 and 7 are olive and gray, not yellow and white - would it be safe to assume that these are the correct two and proceed based on their location rather than on their colors?
2. hanging off the forward lower end (right side in photo) of the fuse block, using the screw that is to be used to hang the relay kit is a relay or terminal block of some sort that is occupying the space intended for the relay kit. It has the number 944.612.551.00 on it - I think it's an OEM part, but can't say for sure since I was not original owner. This is a 1988 911 Coupe with a sunroof - it has no rear wiper and no headlight washers - these are some of the items that pop up when I search on this part number. Anyone have any thoughts? Main concern here is best way to mount the relay kit (in addition to addressing the wire issue above - don't want to start cutting terminals off the wires and find out I cut the wrong ones).
Thanks for any help.
-Tom
Old 04-01-2008, 07:24 PM
stevie 77 930's Avatar
I bought the relay set when i was out in Ventura from the booth. Installation was pretty easy. My fuse panel had the headlight fuse numbers different than the instruction sheet noted, but not a problem. I recommend a 12volt testing light to help identify the correct wires for low and high beams. Very nice setup. I think it took me about 30 minutes.
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 04-01-2008, 08:50 PM
