RSR & 930 brake rotors
Can anyone confirm the fittment of Brembo Racing cast iron rotor XA3.33.10/11 to the genuine 3.0RSR & 78-80 930 hats ??
Rotor is 304mm x 32mm with 12.6mm slots based on 176.8mm PCD As direct replacement for 930-531-047-00 ??? http://forums.pelicanparts.com/uploa...1189733358.jpg |
I can't confirm for sure but it sure looks correct.
It would be nice to know this for sure as another source of these rotors. |
bump
I will get an answer on this Monday and post it here.
Bertbeagle - while you have the measuring stick out, could you also please advise PCD for the 12 (6mm) fasteners on the backing ring ?
Thanks John |
Sorry Bertbeagle - I meant Noah
also given that that rotor is the correct size for use on a 911 or 930 w/ 930 or 993 calipers. I'll bet that Bert's Co. can supply a hat assembly that will work even if they turn out not to be compatible w/ the 930 floating hats.
brake rotor
I believe it is a replacement for the 930 rotor.
This rotor is available from Brembo. It is an old part, apparently out of production for a while. It is now back in production with a new part # (the number on the installation drawing above is the new #). I have ordered some for stock. We will make some aluminum hats for this rotor and the mounting hardware. Availability - around 8 weeks. |
Outstanding!
Bert,
What would the cost per side be with hat and rotor? Cheaper, hopefully than the factory floating rotor? Doug |
I presently have 993 front calipers over 309x32 HD wilwood rotors on an 83SC with 951 7"x16" fuchs. Would it be possible to swap-out the 993 calipers with 930 calipers to facilitate clearance on a 15" fuchs wheel (without further modification) or would I also need to change the rotor/hat referred to in this thread? Thx Martin |
Interesting topic,
I am interested in doing an upgrade to my rsr replica from SC/Carrera brakes to 930 brakes. I can't upgrade to 'Big Reds' because I want to keep 15" wheels. What else would I requre, besides these rotors and hats to complete this brake upgrade? Has anybody used the brakes that pelican sells: http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_BRKprf_pg3.htm#item2 I am a neophyte to brakes... |
The MY78-80 930 rotors and calipers are the best available that will still fit in 15" wheels 2 issues w/ iinstallation on an SC/Carrera 1) front rotors- Absolute hands down best is oem 304x32 annulus w/ floating hats. issue $$$. If BB can supply the Brembos discussed above w/ a flat hat, floating or non at a reasonable price that would be fantastic and the way to go. 2) rear calipers - 930 rotors need some expensive machining to change fromr 3.5" axial mount to 3" axial mount to bolt on an SC/Carrera Other than those 2 issues the 930s are a bolt on, also needed is a 930 m/c also a bolt on |
BertBeagle?
i've tried sending email to: tech@prosystembrakes.com (got it from the prosystems' website) and had it bounce back to me. should i just call the company number directly? thanks. |
use apage@prosystembrakes.com Feel free to give me a call at Pro-System any time. 704-799-8100. Although this week I am at SEMA and Daytona, I typically don't travel much and am usually there M-F. The hats and mounting bobbins are being made and we have a few rotors in now with more on the way. Caliper mounts for virtually any caliper can also be made. I will post pictures of the rotor assembly and details on this thread as soon as we have hats ready. Thanks Ashley Page |
Here are pictures of the hat, bobbins, rotor and installation.
Waiting on rotors :mad: http://forums.pelicanparts.com/uploa...1198189804.jpg http://forums.pelicanparts.com/uploa...1198189832.jpg http://forums.pelicanparts.com/uploa...1198189854.jpg |
any updates on rotor availability?
| All times are GMT -8. The time now is 06:53 AM. |
