-   -   $0.15 Gate Shift Kit for 915 (http://forums.pelicanparts.com/porsche-911-technical-forum/367038-0-15-gate-shift-kit-915-a.html)
Won 09-14-2007 02:11 AM
A picture is worth a thousand words:
http://forums.pelicanparts.com/uploa...1189760094.jpg
That's the first trial. However, the double looped green band was putting too much pressure on the shifter (for my liking anyway) in fore-and-aft direction. So here's the revised version:
http://forums.pelicanparts.com/uploa...1189760201.jpg
... and it doesn't interfere with the tabs or the lockout mechanism:
http://forums.pelicanparts.com/uploa...1189760261.jpg
The blue rubber band is there as a "helper". The shifter doesn't "glide" over the rubber bands when moving in fore-and-aft direction, but there's plenty of stretch in those bands.
I can imagine this little trick has existed for a long time. I came across a "rubber band" reference by BlueSkyJaunte in Pelican archives from way back in 2001. Tbitz made a similar gate shift system using a spring here. I don't claim this to be "my" trick; I just wanted a visual reference in the archives. So next time you buy some groceries, keep those rubber bands and turn your ordinary 915 shifter into an awesome gate-shifter!
PS. Those with sharp eyes may have noticed the rips in the green band. Maybe it will last a couple weeks, perhaps even less. But really, it took me 2 minutes to put those on, and the rubber bands cost virtually nothing, so it's all good.
Porsche virgin 09-14-2007 06:12 AM
Very clever. And it is adjustable for tension! How do you like the "upgrade?" I'm taking my car to a DE this weekend. If I can find some rubber bands and a half hour of free time, I might give this a go!
wide911guy 09-14-2007 06:32 AM
.15 cents? and they say we're not in a recession.
kach22i 09-14-2007 06:47 AM
I'll stick with my spring loaded Seine Systems.
kucharskimb 09-14-2007 07:43 AM
i guess the other good things is when they do break and fall down in the shifter, they are nice and soft... but i do like the way you are thinking :)
Palum6o 09-14-2007 08:01 AM
have you found any particular grocery store produce rubber band better than others? Very clever indeed.
pieterk 09-14-2007 08:03 AM
Maybe try a little teflon or graphite powder dry lube?
Gunter 09-14-2007 09:08 AM
Instead of rubber, try this:
I used a very long spring (3-4mm diameter) attached it to the lever above the lock-out tab with a small hose clamp and then hooked it into the opening on the right side of the shift tower.
Just picture a small diameter long spring with a hook on the end for the window, and the other end attached to the lever above the lock-out tab.
It's all out of sight under the rubber boot.
Keeps it on the 3-4 plane and works good for 3 years now.
Won 09-14-2007 10:08 AM
Again, not my own clever idea, but thanks. I haven't done an extensive research as to what brand of produce comes with the best kind of rubber yet.
I thought about sleeving the part of rubber bands that touch the shifter with a bendy straw, but it works pretty well as it is.
I like Gunter's spring idea too. I may try it when I save up some money to spend, right now can't afford anything more expensive than $0.15 ;)
scottbooth 09-14-2007 10:17 AM
Careful with the bendy straw. That will double your cost of materials. :D
Interesting ideas here...
JBO 09-14-2007 12:37 PM
Gunter - I think I'll try your spring idea. Why do you need a hose clamp on the lever - wouldn't there be enough tension to keep it in place if that end is hooked around the lever above the tab? Just want to be sure I am visualizing the set up properly.
ianc 09-14-2007 12:37 PM
Great work; that should last a couple weeks at least. Then you'll be pulling off the boot again to dig out the bits...
ianc
Jeff Hail 09-14-2007 02:46 PM
Watch out you might take an eye out with that thing!
Actually I just wanted to say that. My Dad used to reiterate that one over and over when I was a kid. It must have worked because I still have four eyes.
Mattcamp 09-14-2007 02:54 PM
It's all fun and games 'til someone looses an eye................Then it's just fun you can't see.
Gunter 09-15-2007 07:24 AM
Sure, whatever keeps the spring up there.
It takes some experimenting with spring size and tension.
It has to be a continuous,long, small diameter spring because it will rub on the edge of the shift plate.
I made a double loop to get the right tension.
Lube everything inside the tower with Moly grease; Moly sticks.
BLEW911 09-15-2007 08:44 PM
:eek::eek: Wow! I tried Gunter's method with the spring today. It works fantastic.I cant believe I never thought of this. I used a universal spring I got at Pep Boys (the kind you might use for carb throttle linkage).I used a pretty stiff one, about 3/8" dia,1 1/2 to 2" long with an inch or two of straight wire on each end. I cut one end short to hookaround the hose clamp, then streched the spring until it reached the shifter plate, measured and bent a hook to hook thru the window. This left all the spring above the plate.
As I said the spring is pretty strong and it feels perfect to me.The shifter has a tight feel unlike the vague sloppiness we all get used to driving an older Porsche. I recommend this!!:eek::eek:
The hardest part was getting the console up and that was easy. Total time: 20 to 30 minutes.:cool:
Don
MattAlpha 09-15-2007 09:33 PM
BLEW911,
A picture is worth a thousand words. Could you take another 30 minutes out of your schedule and take one or two for us and post them.
Thanks,
Matt
MIK911 09-15-2007 11:41 PM
Originally Posted by MattAlpha (Post 3481593)
BLEW911,
Thanks,
Matt
Ditto. Would love to see a pic. My 1 beer buzz has impaired my 'visualization' skills of how/where this spring is supposed to go.
My $0.15 upgrade contribution (not my idea. I believe I read it here on PP yrs ago): spray aerosol silicone lubricant down into the shift linkage, for smoother shifts. I worked for me.
thanks
BLEW911 09-16-2007 12:05 AM
I made a quick sketch. If you can't recognize anything let me know and I'll take pictures for you guys. http://forums.pelicanparts.com/uploa...1189926237.jpg
MIK911 09-16-2007 12:12 AM
Wow. That's a masterpiece. Nice drawing. OK, now I got it. Thanks
Now I just gotta find the correct spring at PepBoys.
