2.7 Flywheel Question
Does anyone know the specs on a 225mm flywheel used on 1970-77 911's. I need the minimum thickness spec and the max run-out specs. The readings I have now are 9.9mm on the thickness and 0.08mm on the run-out. Thanks in advance. Bill (704)829-0976 email billywhitesides1@aol.com
Bill,
Sounds like you have one that still meets specs, per the spec book! The wear limit for thickness is 8.5 mm. The max allowable runout is 0.1 mm.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
