Rennch on YouTube
Ok...so I fibbed a little. This is for my Subaru, not my Porsche. But, you guys are all geniuses, so I thought you could help.
I have two exhaust studs on my Subaru Legacy that have stripped and pulled out of the (soft, aluminum) head. What's my best bet to try and fix it? JB Weld? Or should I try to drill it out and put a bigger stud in the head? Or...? Thanks.
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
Sports Purpose 911 Driver
did they come out of the head or not? if they are out and you have some stud left, I would make a jig to drill out the remaining stud. If they came out but the threads in the head are now bad, then you need to tap them. take some pics and post them.
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
helicoil kit. basically taps in a new thread and you put in a new stud. Do not overtorque the stud when you button things back up.
Tony G 2000 Boxster S |
Rennch on YouTube
That's what I was thinking.
I'll see if my local supplier has one. Thanks!
Navin Johnson
I posted in this thread earlier... dont know what happened to my response... but
http://www.timesert.com do it right... helicoils are bandaids, timecerts are a permanent fix
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
I have used helicoils for years unti I got a Porsche and found out about time serts. after using them a couple times I will never go back to helicoils.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
Rennch on YouTube
That's essentially what I got. It is a 9/16-12 insert with an M-10 Thread on the inside. I have to drill it out, tap it with this 9/16-12 (very beefy thread) then just install normally. My thought is that I might avoid the impact this time. :P
