LinkBack | Thread Tools | Rate Thread |
Removing 996 interior plastic stuff
Have you posed this question with the very active 996 forum over at Rennlist? I guarantee that those guys can answer your question. Here's a link to it. Good luck to you.
![]() http://forums.rennlist.com/rennforums/forumdisplay.php?s=&forumid=60
-Scott 2009 997.2 Carrera 4S 2000 996 Carrera 1984 911 Carrera Cab 2007 Cayman |
Well, I haven't registered with rennlist yet but here's the progress I've made:
Wired the V1 from the pod at the top of the windshield. Tapped the hot and ground from the 3-wire connector that goes to the removable (per the owners manual) lighted section. Unfortunately the hot side is not switched with the ignition, but we'll get over having to turn off the radar detector manually. With some gentle effort you can get the wires out along the glass and off to the V1. I'm still looking for instructions on removing the center console components. Lacking that, I got 12V from the fuse panel and ground from the attachment of the fuse panel to the body (didn't want to put more holes in the body). The hot wire does run outside (visable from the interior) the carpeted panel to join with the ground near the relays. I ran the line up along the HVAC to the center console and tucked the wire under/behind the bottom edge of the carpet towards the shifter. I did a similar routing for the satellite antenna from the passenger side. The sirius unit fits handily in the storage pocket in the console ahead of the shifter. Comparing the 2002 to my 1978 SC, the interior newer one is _so_ finished - to a fault. I had the hardest time finding a ground near the fuse box. Everything is packed neatly into wrist-sized bundles of wires and there aren't screws everywhere. I miss the ability to simply disassemble and reassemble everything. Well, hope this info helps somebody searching later.... mike
'78SC, lots of other boring cars... |
I did a console delete on my car, I don't recall "exactly" how, but it was pretty easy - renntech.org is actually the place to look for "how to" on 996 . I think you start by removing the sides of the console (couple of screws) and it gets pretty clear how you remove components from here on, because you can see how they are attached... it's just a bunch of plastic trays, if it helps I can shoot a picture of my dismantled one, for reference... |
Thread Tools | |
Rate This Thread | |
