1970 911 Transmission / Clutch Fork - Help
I've been chasing a clutch issue on my 1970 push clutch where the clutch mechanism "sticks" for a brief second when I begin to release the cable. Resulting in an abrupt pop into gear and a quick start.
I've spent a ton of time adjusting the new cable to no avail.
Finally decided to drop the motor and RI the transmission.
It looks like the PO put an updated pivot on the trans, but is this amount of play normal? I'm going to have the guide on the side plate fixed, but it did not cause enough deflection to result in adverse engagement.
https://youtube.com/shorts/vlECQUi5ZEc?si=KTnSjRzLRwJYZQTJ
Thank you in advance!
Old 07-21-2024, 02:54 PM
digitaldgp's Avatar
You are missing the Porsche Spring Plate for Clutch Release Fork Genuine Porsche.
https://www.pelicanparts.com/More_Info/91111677401.htm?pn=911-116-774-01-M100&SVSVSI=4231&DID=15215
1970 911T "Albert"
1986 944 Sold
1980 Euro 924 Sold
1967 911 Sold but Greatly Missed!!
Old 07-21-2024, 04:45 PM
Ditto on the missing spring plate and also be sure to put some grease on the pivot bolt.
Old 07-21-2024, 05:35 PM
Thank you for the feedback. I have the spring plate and conical washer installed in the video reference.
In this order: spring plate against trans > conical washed > fork
Old 07-21-2024, 05:51 PM
Wrong. Trans, washer, spring, fork, bolt. If the flywheel was resurfaced and much meat was removed, another THIN washer is installed under the original washer, against the bellhousing.
206 637 4071
Old 07-21-2024, 05:58 PM
Thank you, John. I've seen part diagrams both ways oddly enough. Swapping spring and washer. This one has spring first.
Old 07-21-2024, 06:11 PM
Yeah, seen both diagrams.
206 637 4071
Old 07-21-2024, 06:19 PM
Yes, the amount of play shown on the video is normal. The play will be taken up and eliminated when you attached the tranny to the engine and rotate the ears on the throw out bearing into position.
dho
Old 07-22-2024, 11:53 AM
dho
Thank you.
Old 07-26-2024, 06:01 PM
