-   -   AC question - It's getting around that time. (http://forums.pelicanparts.com/porsche-911-technical-forum/367497-ac-question-its-getting-around-time.html)
JeremyD 09-17-2007 11:25 AM
Yes - my car still has AC - yes it still works - that is until the freon escapes from the original hoses. No I'm not going to bag the whole unit to lose weight. It's a cabriolet and I live in Florida.
I sold some old sails on ebay - who would have thought they were worth so much. Anyway - I planned on just replacing the barrier hoses with the rennaire ones - but now I have a little more cash.
I'm now thinking of doing the:
Rennaire RennAire High Efficiency Serpentine Evaporator $269
Rennaire RennAire Barrier Hose Kit $339
Rennaire Desert Duty front condensor $259
Anybody have the front condensor? it looks like it drops below the bumper a little bit more.
I already have a new drier.
Thoughts on this? Will it enhance my current system? Should I bag the front condensor and spring for the pro-cooler instead? My goal is to replace all these, then have the whole system recharged at a proper AC shop.
Dooable?
Barrpete 09-17-2007 11:45 AM
I would put the condenser & procooler ahead of the evaporator if you're not going to do all of them. I think the lack of condenser area is the weakest link in the system.
The front condenser will be lower than the existing one. On mine it hangs just a shade below that crash bar, where the old one did not. It is almost twice as thick.http://forums.pelicanparts.com/uploa...1190054268.jpg
The procooler also replaces the reciever/dryer.
My system didn't work at all prior to my upgrade so it's hard to compare, but it works fine now & I'm running 134a.
Replacing the hoses is tedious & time consuming, not to mention dirty, but it's certainly doable.
JeremyD 09-17-2007 12:03 PM
Thanks Barrpete - did you go with the procooler too?
scottb 09-17-2007 12:06 PM
Barrpete: Is the thicker condenser now at risk of being smashed when the car goes up or down a step driveway, or over a parking stop?
tcar 09-17-2007 12:19 PM
Take it to a shop and see where it's leaking. Could be seals.
Find out what's wrong before you start throwing parts and labor at it. The stock system actually works pretty well if it's working per spec.
Keep R-12. It cools noticably better than 134a.
Do you have a front condenser now? If not, get one. Don't know how much more effective area the renn front condenser has.
Make sure the condenser fan in the front of the trunk is working - makes a huge difference.
Check that stuff before barrier hoses, procooler and evaporator.
mthomas58 09-17-2007 12:25 PM
I think I've read the thicker desert duty unit comes with spacers to drop the protective cage down and protect the unit from debris. Anyone got a pic of the front with the desert duty condenser installed?
Barrpete 09-17-2007 12:35 PM
JeremyD,
Yes, I have the procooler as well. I went with the Rennaire System II kit plus the Desert Duty front condenser.
Scottb,
Possibly, but in addition to that crashbar there is a protective cage as well. The condenser is still inside the cage and pretty well protected. I think you'd have to hit it pretty hard to damage it. I don't have a pic but I'll try to get one tonite & post it when I get home.
JeremyD 09-17-2007 01:02 PM
I don't normally "throw parts" at any projets - I know the hoses are shot - cracks in many - the hose from the rear lid has a rip in it.
It has a front cooler, and yes, the fan works, and yes, it has an inline fuse. The other I see as upgrades - regular to serpentine - and the bigger front condenser (which I know is what is lacking in these cars)
gtc 09-17-2007 02:20 PM
Good luck with the hose replacement. I removed my compressor, condensers, drier, and hoses this weekend, and those hoses are a serious PITA.
Only when I had everything laid out in my driveway did I realize how ridiculous our AC really is.
tcar 09-17-2007 03:32 PM
Just tryin' to help. Had no idea the condition of your system from your first post.
Good luck.
rfuerst911sc 09-17-2007 04:07 PM
Jeremy you know how friggen hot and humid it is here and for long periods of time. Do it once and do it right, do everything you stated AND the procooler and be done. You will have a system that will last a long time and cool well.
JeremyD 09-17-2007 07:00 PM
Sorry tcar for the grumpy response - rfuerst911sc - yes - it has been extra hot this year. I don't drive this daily - in fact from mid July - to the end of september maybe once a month to keep the fluids circulating - Kind of the reverse from some of our polar brotherhood.
Looking forward to seeing the "desert duty front cooler" Thanks for the responses - I'm really looking forward to having AC that works again.
Barrpete 09-17-2007 08:28 PM
OK, here's a couple of pics. Would have done it earlier but Murphy's Law held true & the camera battery was dead when I got home. Two hours of charging & it's all good.
http://forums.pelicanparts.com/uploa...1190085825.jpg
http://forums.pelicanparts.com/uploa...1190085873.jpg
You can see that it does hang a bit below that crash bar, but probably less than an inch. BTW those scratches on it were by one of the PO's.
tcar 09-17-2007 08:43 PM
It's pretty easy to add spacers to the front condenser guard bar and lower it. Longer bolts plus spacers; may not be quite as strong, but if you're careful.
JeremyD 09-18-2007 06:15 AM
Yes, if I do the desert duty front cooler - I'll also look at extending the font bar down another inch or so just to be safe. I do have a steep drive.
Barrpete 09-18-2007 07:53 AM
Spacers would work, I never really thought about moving the bar. That's not a bad idea. On the other hand, I've had it in now for over a year and no problems so far.
JeremyD 09-18-2007 07:58 AM
thanks barrpete for posting those
JeremyD 09-18-2007 07:59 AM
so, should I go with the procooler instead of the evaporator?
Barrpete 09-18-2007 08:31 AM
Jeremy,
I think both are worthwhile improvements, and either one will be an improvement. But my personal opinion is you would get more improvement from the procooler than the evaporator. Basically because it functions as an additional condenser.
Another thought would be leave the existing front condenser for now & do the procooler & evaporator. Since you're changing the hoses already you will have to access the evaporator anyway which is a bit of a pain. So if you wait until some other time to change the evap you'll have to tear into that again. And if you wait & do a procooler later you will have to change some of the hoses out which would mean getting at the evaporator again. But replacing the front condenser at a later date would be simple compared to either of the other two. Just a thought.
tcar 09-18-2007 08:44 AM
Do you know how much more effective area the new front condenser has than the stock condenser? If it's, say double, I'd do that before the evaporator. Condenser area is the biggest failing with our systems.
How does the procooler function as a condenser? Not questioning, just don't understand how it does.
