Front shocks replacement.
Stupid question but do you guys and girls have any tips on how to get the nut that holds the shocks in place down enough ti get it to grip??
Im having troube with that. Only solution i have is to have a friend pushing down the nut with a piece of pipe that fits over the shock.. Any other ideas??
Track day car: 911 3.2 915 Black 1984 Daily driver: 911 3.2 G50 Blue metallic 1987 Winter car: Volvo XC90 2003 |
Are you sure the inside bottom of the strut is cleaned out? You might surprise yourself and find a rubber washer or too much oil inside. The gland nut should not be hard to fit. Is it possible the shocks are a bit tall for the strut?
If all else fails and you're sure everything checks out, jack up the a-arm a bit and compress the shock.
Tony G 2000 Boxster S |
Friend of Warren
Something there isn't right. Like Tony says I think something is stuck in the bottom of the strut housing.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Are you replacing your strut inserts? If so, are you using the gland nut that came with them?
Different strut inserts use different gland nuts.
Matt. 83 911SC 85.5 944 NA - Sold |
GFCC
Try jacking up the spindle.
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
Thanks tony ill check inside the strut..
I am using the gland nut that came with the new shock. I have compared with the old one and everything seems to be in order. Will have another go at it tomorrow evening... Thanks!
That's weird. It looks like you have Bilsteins. The gland nut should slide right over it down to the strut.
coolcavaracing.com
How about disconnecting it from the top?
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
I solved the problem with some cleaning and some good old violence.
The funny thing was that afterwards when i did the left side everything fit like a glove and the complete job took about 10min. Thanks 4 ur help guys.. Read the Gearbox thread.. That is where it all begins..........
