help! my 66 is sending smoke signal
Hi,
I am in a process of running in my engine after a full rebuild. Tonight while i was driving suddenly the oil pressure was low, idle was really low, engine almost stall and there was strong fuel smell in the car. I pull a side and turn off the engine. There was a big puff of smoke come out of the exhaust as soon as i turn it off. there was a pool of oil about 4" in diameter that came out of the exhaust on the ground. there is a fuel leak from the area in the picture. just on that side. I let it sit there and afraid of cranking up the engine as the fuel leak look pretty serious. the engine is 2.7 rebuild Webber, je piston 9.5:1, s cam. any though how this could happen? what and where should i look for? any suggestion would be greatly appreciated. thanks http://forums.pelicanparts.com/uploa...1190128343.jpg |
| All times are GMT -8. The time now is 01:04 AM. |
